Question about Hotpoint TDC32 Electric Dryer
Is it gas or electric?
I AM A SENIOR LADY, 97 LBS. AND CAN'T SEE BEHIND THIS DRYER AND NEED TO REPLACE IT. IS IT GAS OR ELECTRIC. SILLY QUESTION. PATRICIA
    Problem Solver:
  • 15 Answers
Your post lists it as a "Hotpoint TDC32 Electric Dryer"...that tells me it is electric. Where did you get the information to post this? That would confirm for you.
Posted on Nov 20, 2013
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
The drum turns but I have no flame on my lady kenmore dryer model 6607921
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Dryers
Our Neptune gas dryer seems to work fine but suddenly produces no heat. The vent is clear and the gas line attached and open.
Look at the glow ignitor. If it is broken then it needs to be replaced. About 20 dollars, and a 5/16 wrench will fix this issue, just make sure that you unplug the dryer before you start touching the electrical. This piece is located in the bottom of the dryer behind the back panel.
May 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Check engine light on for evap system
Chevy trucks are notorious for this light. You'll need to replace the EVAP vent solenoid.
Part numbers:
1999-2003: GM #19207762
2004-2009: GM #19207763
Feb 27, 2010 | Chevrolet C1500 Cars & Trucks
I have a gas dryer that has a bad thermostst how can it be replaced Do 110 dryers use more electricity than the 220, are they safe
The thermostat is located in the back, behind the back panel and mouted on the air discharge from the drum before it entered the blower that blows it out via the vent. They are normally snap-disc style thermostats and can be ordered from sears parts direct online or purchased at most sears appliance parts stores. Gas dryers also have at least two over-temperature devices to prevent an overheat condition that may lead to a fire. One is normally a snap-disc thermostat (some with a manual reset) and the second is usually a thermal-fuse that must be replaced...not reset. 110 gas dryers use a lot less electricity than 220 electric dryers since all they have to do is turn the drum and blow the air (heat comes from a gas flame) where the 220-volt electrics have electric heating elements that comsume large amounts of power. Yes, I would consider then safe as long as they are vented correctly.
Nov 27, 2009 | Kenmore 63942 Dryer
It starts runs but push the gas it dies
Most likely the fuel pump. Or your injectors need replaced.
Sep 23, 2009 | 1996 Pontiac Grand Am
I have a lady kenmore dryer it doesn't dry the clothes their is not even heat to dry them.
okay ASSUMING is electric and the dryer operates normally otherwise, you have a bad heating element.Most are not that hard to replace and finding one online is relatively easy if you do a search for the model number or even serial number. If you have basic electrical and mechanical skills and a multimeter to ensure power is off to the unit and that the breaker used for the cicuit isn't compromised you could probably get this done with an expense under $75.00 usually. Check the exhaust ducting to ensure it is not restricted as well.
If your unit is a gas model and the element needs replacing call an experienced repairman.
Hope this assists you.
Sep 03, 2008 | Dryers
Lady Kenmore electric dryer broken start button
it is time to replace it, that sound and smell is from the dryer motor itself.
Jun 28, 2008 | Dryers
Kenmore Dryer Model 417.80042990 problem
Could be just that. Thin coins like that can get into the drum baffles (those 3 "vanes" inside the drum that lift the clothes). It's a simple matter to open the top, remove the baffle(s) and clean them out.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
