Question about Kitchen Appliances - Others
Rx65 ingersoll plate compactor parts
I need a clucth assembly
2 Suggested Answers
  • 338 Answers
SOURCE: viking trash compactor DUC180
any appliance part place you need your model number.
if you have your owners manuel it may say who to call
Posted on Nov 26, 2008
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
How do I choose the right compactor for the job I'm planning to do?
It all really depends on what you want to do. There are three main types of plate compactors.
1. single-plate compactors only go in the forward direction, this is good for a small project like a laying asphalt.
2. Reversible plates are able to go forward and backwards.
3. High performance and heavy duty plate compactors which are usually used for deeper compaction projects.
For your at home project you should be fine with a single-plate compactor.
Nov 11, 2013 | Tools & Hardware - Others
What does a plate compactor do?
a plate compactor uses vibrations and pounding to flatten out land so that you can pour pavement or start preparing for landscaping.
My plate compactor won't start, what could be the problem?
are you using the choke? do you have the throttle on at least a little bit? if these things are ok, you probably need to add oil to the engine
Jan 16, 2013 | Tools & Hardware - Others
Does my plate compactor take regular gas or a 2-cycle mix?
it takes regular unleaded gasoline. the same that you would put in your car
How can i assemble the cg125 clutches assembly?
what do you mean by clutch assy? if your pertaining to the whole assy. 1st the clucth housing fit it in the mainshaft, thenthe trust washer... leave it hold the clutch center put the clutch friction disk then alternate with the clutch plate until you assemble the whole set... lastly put the clutch pressure plate... then put the whole assy to the clutch housing(clutch outer comp. then assemble the clutch springs then the clutch lifter... thats it...
Feb 01, 2011 | Honda CG 125 Titan ES Motorcycles
Does 15" trash compactor need
If the current rating on the name plate is 15A or better, I would have it on it's own breaker
Dec 27, 2010 | KitchenAid P Series Trash Compactor -...
GE Profile compactor
Here is an assembly drawing of your compactor.. Please note item # 102 ( direction switch) ..That may be affecting the perfomance of your motor or your motor may have a dead spot on the windings.. Here is a link to a website for parts that coincide with this drawing.. There isn't an awful lot to a compactor in terms of hardware so good luck.. Hope this helps..
Here's the link for parts... http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
Aug 19, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Problem
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Nov 20, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kitchen Appliances - Others Logo
69 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
