Question about U-Line Echelon Combo® CO2175DWR Compact Refrigerator
Fan motor in freezer is making loud noise & not making ice
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Sounds like fan needs repladed
Posted on Nov 22, 2013
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
At first the refrigerator side was freezing everything and the freezer was fine, except the ice & water quit working. I replaced the filter & it worked for a few days then it was back to the same...
if the fan was loud you could have a bad evap fan motor,is there ice on the inside back wall of the freezer?if there is you have a defrost problem and ice could be built up around the fan motor and the blade,when the blade hit the ice that could be the noise you were hearing and now the ice is stopping it from spinning at all.if there isn't any ice on the wall you could have a bad computer board,part number wr55x10942,i've seen g.e.'s that when the water and ice didn't work and the temp was warm it was the board but when you say the fan was loud it makes me think you could be iced up in there.also if the fan motor was reving up and slowing down the board could cause that,let me know if there's like snow or ice on the freezer wall and i can help you out
Sep 30, 2010 | GE PSS26LGR Side by Side Refrigerator
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Problems
Check to see if bottom freezer has not iced over, the back panel at rear of freezer has a small fan in it to circulate air and if the freezer coil in froozen /iced over the fan will hit the coil making loud noise.
try defrosting the freezer?
Jan 08, 2010 | Fisher and Paykel E522BLE Bottom Freezer...
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Making a loud noise
yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
May 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
U-Line Echelon Combo® CO2175DWR Compact Refrigerator Logo
55 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
