Question about Omega MARS-22 Remote Vehicle Starter with Keyless Entry
Mars 22 car starter. car starts for a second then turns off
The mars remote starter is for a 2008 f350 diesel pickup. it starts with the remote when you press start and shuts off within a secound. if I leave the key in and press start and take the key out the truck remains running. can anyone help me?
    Scholar:
  • 96 Answers
Your truck most likely has a chip in the key. You will need to contact the maker of the remote start kit you have and see if they make a kit to bypass the chip key.
Posted on Nov 20, 2013
Testimonial: "the remote was working before. could it be a security problem?"
3 Suggested Answers
MECP Guy
  • 344 Answers
SOURCE: My 2007 Ford Edge W/ Mars 22 remote start will
put your key in the ignition leave it in the off position, push your remote start button, if it starts then it has something to do with the transponder bypass "key in the box" or the loop around the ignition switch under the plastic cover
Posted on Feb 24, 2010
  • 21 Answers
SOURCE: car starts but shuts off after 15 seconds
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Posted on Oct 26, 2012
I have a 2008 F350 6.4 diesel with no crank no start pats light flashing rapidly and airbag light flashing
you must disconnect the battery for 5 minutes then when you reconnect the cables press the alarm deactivate button on your remote I believe your car will start and when you see the pats light rapidly flashing the cars in theft mode and will not start
Nov 04, 2016 | 2008 Ford F-350
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
Diesel. Reduce power lite turned on. Shut off engine and started back up - lite is off. Can it be driven?
Jerry, Drive to a good shop. So many things can cause reduced power light unfortunately. The first step would be to get the truck hooked up to a scanner/computer and have the computer scanned for trouble codes. One thing that you could try is to drain the water from the water separator that is mounted on the frame under drivers front door. If the PCM picks up on water, power is reduced until water is removed/drained. It could be an exhaust sensor that is reading faulty. Unfortunately from here its impossible to tell you exactly what the fault is because there are just so many engine sensor inputs that could cause your problem. Check the attached links, forums,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reduced Engine Power Light Wrench Showing Ford Powerstroke Diesel Forum
08 Reduced Engine Power
Regen Reduced Engine Power Light Ford Truck Enthusiasts Forums
Help reduced engine power light comes on
Dec 29, 2015 | 2008 Ford F-250 Super Duty
Truck starts then shut off then starts then shuts off its a mars but dont no what kind
Mine was doing the same thing. Find your Mars box, then...
Sep 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
Truck starts shuts off starts shuts off starts shuts off.
I had the same problem. Here is the link to get the manual.
See page 20/21 (picture)
Find your Mars box. You will need to turn either the Smart Start adjust screw or the Tach Wire adjust screw until the LED LIGHT is blinking consistenly.
Feb 07, 2011 | Omega MARS-22 Remote Vehicle Starter with...
My 2007 Ford Edge W/ Mars 22 remote start will start for 2 seconds when you hit the start button then shut off then start again then 2 seconds later shut off and will repeat this 2 more times, then will...
Feb 23, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Car starts but shuts off after 15 seconds
Feb 10, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Every 20-30 starts my starter solenoid 20am fuse, 2000 dodge ram
You most likely have a internal short in the starter. You could pay to have a cranking test done or just replace the starter.
Jul 31, 2009 | 2008 Dodge Ram Pickup 1500
1990 Ford Superduty (F350) 7.3 Diesel= Won't start, doesn't crank
if its an auto. check the reverse neutral safty switch it may be thinkin its in a gear and will not start
Jun 07, 2009 | 1990 Ford F350
Omega MARS-22 Remote Vehicle Starter with Keyless Entry Logo
277 people viewed this question
Top Omega Juicers Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Omega Juicers Vehicle Part and Accessory Expert? Answer questions, earn points and help others
