Question about Jaguar 1998 XJ8 Vanden Plas
Coolant coming out randomly - Jaguar 1998 XJ8 Vanden Plas
    Master:
  • 613 Answers
Apparently you have a leak, but failed to disclose where. An internal leak would come out of the exhaust pipe and would be white smoke.
Posted on Dec 08, 2013
Coolant wetting floor mat on driver side:2002 suzuki grand vitara xl-7 2.7l 4x4
There's only one place coolant comes inside the cabin - the heater core. The only fix is to replace the heater core.
Jan 18, 2017 | Suzuki Cars & Trucks
Engine cuts off while drving. May be related, the warning beeper randomly beeps especially when on a rough road or going around curves to the right, not left ??
Check the coolant level in the radiator at the cap as it may be the low coolant warning system that is activated as the water runs away from it as you change direction. If it is serious enough the engine light will come on and the CPU will send the engine into limp home mode.
Oct 26, 2013 | 1990 Honda CRX
Engine coolant Temperature gauge fluctuates
Watch the temp gauge when the electric radiator fans come on. The temp sensor that controls when the fan comes on may be faulty.
Oct 11, 2012 | 2000 Pontiac Bonneville
2002 Honda Civic...The car is overheating randomly. Replaced the thermostat,and fan relays. Car runs fine and then randomly overheats with gauge going way up and then sometimes coming down.Overheating and...
RADIATOR COOLING FAN NOT RUNNING COULD BE BAD ENGINE.COOLANT TEMPERATURE SENSOR IS FAULTY IF COOLING FAN IS NOT TURNING ON AT SET TEMPERATURE OF 196 TO 203 DEGRESS.CHECK SEE COOLING FAN RUNNING WHEN ENGINE RUNNING HOT.IF YES FLUSH RADIATOR , FLUSH ENGINE BLOCK, HEATER CORE,REPLACE RADIATOR CAP.MAKE SURE YOU HAVE 50/50 ANTIFREEZE AND WATER IN THE COOLANT SYSTEM.CHECK WATER PUMP WEEP HOLE IF LEAKING REPLACE WATER PUMP. IF COOLANT FAN DONT TURN ON 196 TO 203 DEGREES, YOU HAVE FAULTY COOLING FAN,SHORT IN FAN WIRING OR ENGINE COOLANT TEMPERATURE SENSOR FAULTY.IGNITION TIMING WILL CAUSE ENGINE TO OVER HEAT.
Aug 17, 2011 | 1999 Honda Civic
Coolant is full with correct solution mixture but coolant light comes on and off randomly
sound like you have faulty low coolant level sensor in the coolant expansion tank.make sure coolant expansion tank has coolant should be on full hot mark when engine hot been driven.cold engine coolant level in expansion tank should be on full cold mark.
Apr 15, 2011 | Saturn Ion Cars & Trucks
So, my 2001 V8 Jeep Grand Cherokee Laredo is very slowly leaking coolant. I replaced the heater core in 2009 and the symptoms that the Jeep expressed then are not happening now. However, the low coolant...
are you mixing the coolant with water if yes,you need to just put straight up anti freeze ,because water evaporates at high temperatures .. also keep resorvoir full at all times there is a sensor in the tank that when is low it makes the check coolant light come on ,,....good luck
Mar 21, 2011 | 2001 Jeep Grand Cherokee
What could cause frequent overheating and random misfire on diagnostic
Frequent overheating is caused by low fluid level for coolant, coolant fan not working, or stuck closed thermostat.
The random misfire could be caused by a bad sensor like an O2 sensor, for example.
Wish you luck on this repair.
Oct 08, 2010 | 2002 Mini Cooper
Low coolant light
the sensor is replaceable and runs about $15
Sep 20, 2008 | 1996 Pontiac Grand Am
Jaguar 1998 XJ8 Vanden Plas Logo
Top Jaguar Heating & Cooling Experts
Lawrence Oravetz
michael vanier
NOEL
NOEL
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
