Question about Garden
What is the factory setting for lowand high screws on 25cc craftsman blower
    Problem Solver:
  • 7 Answers
If the two screws are side by side, one is the high speed mixture screw and the other is the low speed mixture screw. To set the high and low adjustment screws, tighten the screws in until they stop, don't force the screw after it stops. Back each screw out 1 1/2 turns. The engine will start and run here if everything else is ok. Fine tune each adjustment screw by closing the screw off (CW) until the engine runs rough. Back the screw out (CCW) until the engine smooths out. Run the engine at full speed and adjust the high screw. Let off the trigger and adjust the low screw. Once the mixture screws are adjusted, you can turn the idle screw to adjust the idle speed. It can take some time getting it all adjusted.
Posted on Nov 21, 2013
Why doesn't leaf blower rev high
Try adjusting the high side adjustment by turning it CW a quarter turn.
Oct 13, 2014 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Starts but wont run with choke off
My Yard Works was set at the factory to run with the choke partially on. They said it has something to do with the air pressure where we live. Otherwise if it has to have the choke on full then there should be a screw to set it so it will run with the proper setting
Jul 09, 2014 | Craftsman 25cc Gas Line Trimmer
How do I adjust the carburator on a craftsman blower
All carburetors have 3 screws high and low and idle, then screw high and low all the way in, then turn them back 1 and half that should be factory settings go from there. start with the high idle back it out slow until it sounds good. My blower ran good on two turns out on high idle then three turns on low idle. Good luck...
Sep 15, 2012 | Craftsman Garden
On Craftsman Blower serial 07101 N200438=25cc TWC Model 358-794964
I NEED TO REPLACE THE GAS LINE ON MY CRAFTSMAN MODEL 358-794964
Jun 26, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Craftsman 25cc weedwacker (358.791030). Zama carburator (C1U-W19) Just rebuilt carb but did not adjust low speed/high speed screws. Starts on first pull (with choke lever actuated), and after warm up,...
need to adjust the high sscrew. i do mine in 1/4 turns. start machine, full throttle, adjust the h(high) til it clears up.i would start by turning 1/4 counterclock wise, just remember to keep track, in case it runs worse, the put it back to orig. then try the other way. but i suggest 1/4 turn at a time
example... think of a clock when turning screw. straight up and down, 12oc, 1/4 turn will be 3oc, another 1/4 will be 6oc, and so on. hope it helps!
Sep 17, 2010 | Craftsman 25cc Gas Line Trimmer
Sears Gas powered blower 25cc/1.5 Cu. in 2 cycle 200 MPH/400 CFM Where's the fuel filter, so I can clean it?
I have craftsman 25cc 2-cycle blower-It wont turn over-I put new spark plug and cleaned filter. It dosen"t seem to be getting any gas. How would I know if its the gas filter and how do I put new one on? thanks,mh
Jan 23, 2010 | Craftsman 4 Cycle Blower/Vac
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
