Century 3 control 7cv91sa - Heating & Cooling
Why won't my headlights on my 2002 Buick Century go off. I had to disconnect the battery cable.
there several things that keep the headlamps on #1 the beam selector lever rod is stuck on . does the beam selector move freely and click when changing beams. # 2 dash pad covering ambient light sensor #3 headlamp on sense wire shorted to power . #4 Bad body control module. #5 headlamp control relay faulty.
Jun 19, 2014 | 2002 Buick Century
Low trac 2001 Buick Century
Your the first in 3 years to ask if you should park it
Very good question & best way to think
You can drive it until you check for codes
& then have the ABS Braking System diagnosed
as trac control is a near useless part of it.
May just have a bad Wheel Speed Sensor
Nov 24, 2012 | Buick Century Cars & Trucks
How do you replace 98 Buick century evap emission control system
If you are getting a code saying that there is a problem with your evaporative emission control system, it is often related to the gas cap. In many cases replacing the gas cap will fix the problem.
May 04, 2011 | 1998 Buick Century
Spark plug firing order in a 1980 buick century
1980 Buick Century 3.8L 2BL OHV 6cylThe Firing Order:
Firing order 1-6-5-4-3-2 ------- front | 2 4 6 | of | |Distributor rotates clockwise vehicle | 1 3 5 | -------
Hope helps.
Aug 19, 2010 | 1983 Buick Century
1998 buick century heat control won't switch between defrost,vent,bilevel etc. has 3 knobs on control head and the furthest right controls this. blower and temp. controls work o.k.
these are common for knobs breaking, pull knob off and look at the back see if its broken, pull a good one off and compare,il bet you its broken, so it doesnt spin the shaft it feels like it is but it doesnt, hope this helps,
Mar 09, 2010 | 1998 Buick Century
What is the firing order for 1988 Buick Century 6cyl
The firing order for a 4-cylinder 2.2L Buick Century is: 1-3-4-2. The distributor rotates in a clockwise direction, with #1 plug wire located at the upper left of the distributor The firing order on a 3.1 v6 is simple. 1-2-3-4-5-6 See a diagram of the 3.1 and 3.8 here. http://www.2carpros.com/forum/1999-buick-century-spark-plug-firing-order-vt177159.html http://autorepair.about.com/od/enginefiringorders1/
Jun 11, 2009 | 1988 Buick Century
Turning Signal Fuse Keeps Blowing - 1998 Buick Century
one of the bulb holders is no good or wires trapped somewhere that feed indicator lights
Nov 16, 2008 | 1998 Buick Century
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
