Dell V520 wont print black
Full new cartridge - printer wont print black after replacing
yooperbud
  • 8637 Answers
SOURCE: Black ink cartridge is 2/3 full, but doesn't print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
ginko
  • 19396 Answers
SOURCE: printer replaced with black cartridge, and doesnt print
Either the print head for black is faulty, or the wiring to the black print head on carriage are broken. Try also cleaning the metal sensor to the black cartridge inside the ink carriage.
Posted on Apr 18, 2009
SOURCE: my printer dell photo 924 wont let me switch to
Had the same problem. Go to file, print then go to advanced tab and click on the more options button...then click use black cartridge to print black and white and VOILA
problem solved :D
Posted on Jul 08, 2009
  • 26 Answers
SOURCE: MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
Posted on Aug 18, 2009
SOURCE: dell 926 photo printer will not print black ink.
I'm am having the exact same problem with a new Dell 926!
Posted on Feb 16, 2010
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
My printer wont print in black. the color cartridge works.
Dear You should refill your black ink cartridge if possible otherwise replace with new one black ink or cartridge.
Good Luck
Sep 10, 2009 | Dell 924 All-in-One InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
My printer dell photo 924 wont let me switch to black and white printing only and it's just using my color, it's a brand new cartridge and shows it's full. what should I do?
problem solved :D
Apr 06, 2009 | Dell 926 All-In-One InkJet Printer
Wont print black
clean the contact on the printer and the ink cartridge. do not use paper towel. use coffee filter.
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
281 people viewed this question
jasbo
jasbo
