Question about Radio Communications
Bluetooth connection failure between a Droid X and Nakamichi Bluetooth headphones
I followed the very simple instructions to the letter. Turn on phone, turn on headset, scan for bluetooth devices and then nothing happens.
  • 91 Answers
Follow some solotions
1. make visible bluetooth
2. delete some paired devices then pair your device
Posted on Nov 20, 2013
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Radio Commun... Master
  • 1,001 Answers
The buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music . Amazon com Charm sonic Bluetooth Headphones for Gym Runing Exercise Green...
Posted on Jan 10, 2017
SOURCE: Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Posted on Jan 21, 2008
Spiker-123
  • 9 Answers
SOURCE: Jabra BT135
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
Posted on Apr 22, 2009
rudydanielle
SOURCE: bluetooth headset hb600 does not pair up to k800i
Hold down the volume buttons on the side till the button on the front turns red. Then try to pair, your phone should find it right away...put in 0000 and push connect on your phone. I just paired it with my iphone.
Posted on Jul 24, 2008
boopleloo
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1:
Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
Posted on Dec 19, 2008
Found this at another site. It worked for me. Good luck!!
Posted on Dec 22, 2008
What is bluetooth for?
    • Connect a Bluetooth audio device (Windows 10)
    • Miracast wireless displays
    • WiGig wireless displays
    To connect your Bluetooth headset, speaker, or headphones to your Windows 10 PC, you'll need to pair the device first.
    1. Turn on your Bluetooth device and make it discoverable. The way you make it discoverable depends on the device. Check the device info or website to find out more.
    2. On the taskbar, select the action center icon and make sure Bluetooth is turned on.
    3. In action center, select Connect, then pick your device.
    4. Follow any additional instructions. Otherwise, you're done.
Nov 16, 2016 | Computers & Internet
Headphone connection
The laptop must have a Bluetooth radio, check the Control Panel for a Bluetooth setting, then buy yourself a Bluetooth headset and follow the instructions.
Feb 18, 2015 | Computers & Internet
Plantronics Voyager Pro bluetooth headset seems to be stuck in pairing mode. The lights flash red and blue, my motorola droid will show paired but not connect ed. If it does connect at all it will drop...
You want to turn off the power to your headset and turn off your phone. Remove for 30 seconds the battery from the phone and reconnect. Then follow the pairing instructions found on pages 4-5 in this link for the Plantronics Voyager Pro+.
Good luck from Headsets Direct!
Sep 01, 2011 | Plantronics Voyager PRO Bluetooth Headset
Had lost my Plantronics 220 for a year. am trying to pair with my Droid. can't remember how to do this. don't have any paperwork with me right now. what do I need to do? simple instuctions for a...
To find the User's Guide, check here: http://www.plantronics.com/us/support/docs/index.jsp?prodId=prod5920006
On Page 4 and 5 it details how to Pair the Bluetooth device to your phone.
For an Android 2.2 phone:
  1. Turn Bluetooth Headset on according to instructions in the Users Manual
  2. On phone, Go to Applications --> Settings--> Wireless and Network --> Bluetooth Settings
  3. From this menu you can turn Bluetooth on and once its on you can choose to Scan Devices
  4. Select your headset from the list.
  5. You will be prompted to enter a PIN or Code. By default it is 0000 (4-zeros)
  6. You devices should now be paired.
Hope this helps.
May 12, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Hi, I buy a new Plantronics Backbeat 903, but right now it's unrecognizable by any movile, can you give some hints on how to fix that problem. I try with an LG P500 and Nokia 6110, no answer...
Delete the device from the phone, then re-pair the headphones with the phone. If you just turn on the headphones, the device cannot connect because the headphones store the information that you already deleted it on the phone. To pair again with the other device (like a computer, phone, etc) you need to turn off the headphones, then turn on the headphones but press the power/pair button and hold until the led flashes red and blue (like 10 sec after the led turn only blue) to put it in discovery mode. Then turn on your phone and follow the instructions for finding (discovering) your bluetooth headset.
May 06, 2011 | Plantronics Backbeat 903 Bluetooth...
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
Feb 22, 2011 | Plantronics Backbeat 903 Bluetooth...
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
I have the droid backflip and my boss has the first droid from verizon, neither can find the bluetooth headphones (motorokr s9 black & red) how can i pair the headset to my phone if i cant find it
Make sure you put the headset into discoverable or pairing mode, there should be specific instructions that came with your head set to do this, then use the droid or the backflip to scan for the devices and it should find them.
Oct 18, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
How do I sync my motorola H710 bluetooth with my Motorola Droid?
Here's the instruction manual for the H710:
Motorola H710 download instruction manual .pdf 2MB
You'll have to check your owners manual for your Droid, but it's probably under Settings > Connections > Bluetooth (Turn on) > Discover (Pairing code 0000)
Feb 04, 2010 | Motorola Mobility H710 Bluetooth Headset
Setup Bluetooth Wireless headphones
Each brand has it's own peculiarities and you did not specify the brand. I would suggest turning off the headphones, resetting the transmitter (turn off and on again for separate devices) and then pressing and holding the 'on' switch for 15 seconds or so. You may see (in some models) a light start to blink blue then red and back. This should indicate that the receiver (headphone) is trying to find a transmitter to pair with. Hope this helps.
Nov 27, 2007 | Logitech Bluetooth Wireless Headphones
Radio Communications Logo
436 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
