Question about Janome Sewist 625e
Janome 625e needle threader stuck
The needle threader is stuck in the down position. Any ideas on how to get it unstuck
4 Suggested Answers
SOURCE: Janome MC 10001 auto. needle threader stuck in up position.
I have a Janome 10001 and the needle threader is stuck in the down position and I cannot get it up. Help, please !!!!
Posted on Jan 11, 2010
Sewtech1
  • 69 Answers
SOURCE: needle threader for the Janome won't drop down.
It seems light your needle thread motor is not working. It will be hard to help you online unfortunately
Posted on Jan 20, 2010
RichSew
  • 194 Answers
SOURCE: janome 1860 needle threader
If the hook is bent, you might be able to straighten it, but I would go to my dealer and purchase a new threader. It is much easier to replace it.
Posted on Feb 09, 2012
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
Automatic needle threader stuck
You may have a thread stuck in your bobbin area. Remove your bobbin, brush gently with a clean soft brush to remove dust and/or thread bits, then gently wiggle your hand wheel back and forth, and brush again. This should free up your machine.
Jul 09, 2014 | Janome Sewist 500 Sewing Machine
The needle threader is stuck down on my Emerald 116
Typically the threading device moves downward and then rotates sideways. Which function is stuck? Is the shaft bent? In any case, the threader apparatus is removable. If you need help disassembling, get a service manual for that model (probably about $20 on the internet).
Feb 11, 2013 | Husqvarna Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Automatic needle threader stuck in lower position
So sorry I don't have an automatic threader so I'm no help in this department. Good luck!
Oct 26, 2011 | Singer 3116 Simple
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
Dec 03, 2010 | Elna 2007 Mechanical Sewing Machine
How do I adjust the needle shaft position on my Hobbylock 788. It somehow shifted up.
take the end cap off and follow the needle bar up until you see a block with a screw in the middle of it.bring the needle bar down useing the handwheel to its lowest position loosen the screw and you should be able to move the needle bar if you have a needle threader you can use it to reset the height of the needle bar just bring the threader down and then lower the needle bar to where the threader fits into the eye of the needle like it would if it were being threaded
Jun 30, 2010 | PfaFF Hobby 4260
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Feb 12, 2009 | Janome Memory Craft 9000 Computerized...
Janome Sewist 625e Logo
47 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
