Question about Pantech Cell Phones
HOW TO HARD RESET A CHERRY MOBILE SUPERION?
NOT TURNING ON AT ALL. WHE I PRESS THE POWER BUTTON THE LOGO OF CHERRY MOBILE AND ANDROID WILL COME OUT BUT AFTERWARDS IT WILL GONNA RE-START AGAIN.
Here is a link video solution for you hope it helps
http://www.youtube.com/watch?v=NvWXxYXqHko
Posted on Nov 20, 2013
Bajanguru
  • 7752 Answers
SOURCE: i have mobile motorla model v3i when i power on its restarting
the firmware on the phone needs to be reflash on the phone to correct the problem you are having take the phone to a mobile service center and have it done.
Posted on Dec 28, 2008
SOURCE: 5310 blank screen
Check if your memory card is corrupted or damaged or the firmware is also damaged and needs to be reinstalled.
I advise that you visit a nokia store and get your phone checked up.
Posted on Dec 23, 2009
supernova278
  • 1932 Answers
SOURCE: my nokia 5130 express music
This is a software problem.Just take the mobile to nokia care and they will reinstall the software and problem will be solved.
Thank You
Posted on Nov 19, 2010
Prof  Henry
  • 209 Answers
SOURCE: i have Nokia 3120
The battery is weak, replace it and it will work fine.
Posted on Aug 27, 2011
jadelefave
SOURCE: my cherry mobile nova android phone keeps on powering on and off every 5-15 seconds, what should i do to stop it? i can not use my phone because it will keeps on restarting
Your phone is stuck in a "Boot Loop". This was most likely caused by a newly installed update, program or an unfortunate virus. Start by removing the battery for about 30 seconds. Push down on the power button while the battery is out, to release all memory from the board. Re-install the battery and turn the phone back on. If it is still stuck in the boot loop, you will need to perform a master reset.
WARNING!!! A MASTER RESET ERASES ALL DATA ON THE PHONE AND RETURNS IT TO THE ORIGINAL FACTORY SETTINGS!
PROCEED AT YOUR OWN RISK!
Master Reset for your device is done by turning off the phone. Then press and hold the camera button + volume up + power button. Keep holding even when the phone turns on. Navigate with the trackball, scroll down and click on Wipe data/factory reset. Hit yes to confirm everything and let her rip.
Posted on Dec 20, 2011
My samsung S3 mobile is frees and not turn on kindly give me solution
this will wipe your phone and any glitches that may be associated with it:::sgs3 hard reset or reset Galaxy S3: PRESS AND HOLD VOLUME UP + Home Button + Power
Turn the phone off
Press and hold Volume UP and Home (center) button
Press Power until the phone vibrates
Wait until you see the Android logo then release all the buttons
Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side)
Select YES...delete all user data with VOLUME DOWN and then Press Power
After format, press Power again to reboot the phone (select reboot system now)
Feb 26, 2015 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
How do i get to the BIOS on a craig 7" netbook clp218?
I have no idea about these craig things which are Android machines, Try this.
Cannot be worse than you got.
How to do a hard reset using external keys? If your tablet is completely locked up and you cannot access the menu functions, use the following method to perform a hard reset using external keys on your tablet:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
If it doesn't work try search engines for 'Android tablet hard reset'
Sep 10, 2014 | Computers & Internet
My daughters my tablet2 by bush has,frozen what do I do
if you can remove the battery start there. is not try to hold the power button for 1min. if that still doesn't work follow the bellow instructions
When Hard Reset is Necessary for Smartphones or Tablets ?
1. Forgotten Pattern Lock on Android Tablets or Smartphones.
2.Too many pattern attempts / Reset user lock.
3. Tablets PC,Smartphones stuck on Gmail account.
4. Android Tablet PC stuck / freeze on Android logo.
5. Tablet Android or Smartphones hang on start-up / Multiple errors generating by OS.
6. Android market having problems or generating errors.
7.Upgrading to new Android version.
Make sure to charge battery upto 60%.
How to Hard Reset Argos CnM TouchPad Android tablet pc ?
  • Make sure the tablet is charged up to 60%
  • Turn off the tablet completely .
  • Press Volume + button , while holding Volume + button , plug in charger.
  • Release the volume + button.
  • Press Volume + again and press Power button to boot the CnM Tablet.
  • When Android logo appear , release the volume + button.
  • Press Power Button again and press volume + button , Recovery Menu will be appear .
  • Press the volume down and select "wipe data/factory reset"
  • Power button to select it
  • You will see "Yes - delete all user data"
  • Select "Yes"press "Power" button to select it
  • Formating will start. it will delete all user data .
  • Few seconds later, you should see the recovery menu again. Select reboot.
  • It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
you are done.
This Hard Reset method will work with all models of CnM touchpad tablets.
Jul 25, 2014 | Audio Players & Recorders
How to reboot cherry mobile spark tv?
Here`s how to hard reset you Spark Tv
1. Turn off the your Cherry mobile Spark
2. Press power button, Volume down and home button at the same time.
3, Wait for a Spark TV logo then release power buttons and continue holding Volume down and Home.
4. Scroll down and select wipe data then press home button
5. Select reboot and your phone will be unlock but all files in the internal storage will be deleted.
or try this
SPARK TV cherry mobile HARD RESET too many patterns attempt solution
POWER ON + VOLUME DOWN BUTTON press together in 20 seconds or until the Android system recovery <3e> appeared
Press volume down to wipe data/factory reset then press power on
Press volume down Yes -- delete all user data then press power on
Press power on to reboot system now
After reboot HARD RESET was done
May 20, 2014 | Nokia E Cell Phones
Forgot my password on my cherry mobile phone t2i
you need to hard reset the unit.
  1. make sure the batteries are full
  2. press and hold the power button until mene is displayed
  3. press volume button to scroll up and down use the camera button to select
  4. select factory reset
some of your installed apps may be lost during this process just re install them
May 09, 2014 | Cherry Electrical T20 Mobile
Reset tablet
Hello,In order to hard reset your tablet, the steps given below must be followed:
  • Ensure that the tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Power button in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
Hope this helps..
Jan 12, 2014 | Computers & Internet
I put a password on my android tablet and now i dont remember the password
Make sure you backup your files by connecting it to a PC (if you have access to one) via USB cable,you will have to do a hard reset, otherwise there is no other way to get past the lockscreen (unless you have a recovery option with your email address)
Below is the process to tell you how you can hard reset your Samsung tablet (should work with any tablet):
  • Ensure that the Samsung tablet is powered off.
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
  • Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your Samsung tablet.
Oct 21, 2013 | Tablets & eReaders
Cherry mobile Q6i hard reset using buttons?.
ahhhh , if i press the 3 button the power button is doesn't work
Apr 11, 2013 | Cell Phones
T20i cherry hard reset
Depending on your Android version, you must find the option "BackUp & Restore".
Settings > Privacy > BackUp & Restore
Caution: you will lost everything with the factory reset. Don't forget to backup your data first (photos, videos, sms,...)
or :
Turn Off Your Phone
Hold the Hold the Volume up + Home + Power key at the same time until you see the Android Logo
Once the Android recovery mode appears, select: swipe data / factory reset with the volume key and the power button to make a selection
Dec 28, 2012 | Cherry Electrical T20 Mobile
Cell Phones Logo
1,545 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
