Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer lxr7244jq1 timer won't let water in but will spin
When I move my dial to Reg wash it will not add water but if I move the dial to spin it will spin. Help could it be the timer?
    Problem Solver:
  • 23 Answers
It's probably the inlet valve, not the timer. If you check for voltage/drop at the valve wiring, you can be more sure. With one wire disconnected from the valve, you should see line voltage between the wires, when the unit is plugged in, and the timer is on in fill mode.
I've probably changed a hundred bad valves for every bad timer, if you don't have a voltage tester or just want to take a chance. They're cheaper too, and a little easier to change.
Posted on Nov 20, 2013
  • 12 Answers
SOURCE: washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Posted on Nov 22, 2008
  • 32 Answers
SOURCE: Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Posted on Apr 22, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
mhamlin63
  • 138 Answers
SOURCE: WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
Posted on Jun 29, 2009
honeymokey
  • 3113 Answers
SOURCE: washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Posted on Jul 02, 2009
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Dec 13, 2017 | Washing Machines
Kenmore 70 washer, does not move from one cycle to another
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd also look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 26, 2009 | Kenmore Washing Machines
My washer gets stuck on wash cycle...
I would replace the timer . Pt # 3954071 . If the model number above your thread is correct .
Sep 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Awful noise won't rinse wash or spin, on my whirlpool washer
http://www.youtube.com/watch?v=WLPGs2UMUJc
This video will show how to replace the direct drive coupling that runs the transmission.
Jul 05, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Jun 29, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Washer fills but won t advance to the next setting for all cycle
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
Dec 03, 2017 | Whirlpool Washing Machines
Washer won't drain or spin out the water
i pulled the motor out od the bottom and pulled a baby sock out of the gear in the balis tank
Aug 21, 2008 | Washing Machines
Aggitates but does not spin out to rinse
From the description of your complaint, I would replace the timer to correct the malfunction.
May 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
