Question about Epson Stylus R265 InkJet Photo Printer
Epson stylus photo R360
Hi there when i first installed my printer every thing was fine then i had to reboot my computer so when i reinstalled my printer the lanugage was in german ive reinstalled it selecting english as my lanugage but its still in german is there any thing else i can try thanks polymer25
I had the same problem and so contacted Epson support. This was the reply, it worked for me.
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab. Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Open up Windows Explorer or My Computer, and navigate to the drive (usually C) where windows is installed. Browse to the folders called windows/inf on XP, or winnt/inf on 2000. If you can not locate the INF folder please go into the START MENU and select RUN. If there is any text within this box please remove and type C:\windows\inf and press enter. Please be advised that 'C' represents the hard drive on your PC. If your hard drive is a different letter please amend as necessary.
Find the files labelled OEMxx.inf, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says "SEIKO EPSON" or "EPSON" within the first few lines, then you need to close the file, and then delete it. Repeat this until all EPSON INF files are removed.
Step Three:
Staying in Explorer or My Computer, stay within the windows folder (winnt folder on 2000) and navigate to system32/spool/drivers, and go into the folder named "w32x86". Delete any folders that begin with "epson", and then restart. Once rebooted, empty the recycle bin, and attempt reinstallation of printer, using the instructions below.
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinXP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Once this has completed installing, please remove the CD from the CD drive and reboot the PC. The foreign language tabs will now appear in English.
Posted on Oct 16, 2007
I need an epson stylus photo R360 user manual.Help please.
You can view FAQ and download User's Guide and Setup Guide in PDF format for your printer on this page:
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-R360/Drivers-Support?supportLandingPage=true
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Office Equipment & Supplies
I have a EPSON Stylus Photo RX520 printer, when i plug it in to my computer it comes up as a unknown device. i've tried getting latest drivers for it but it still doesn't work. how could i fix my problem?
Hi, welcome to FixYa.
Usually, most printer driver need to be installed first BEFORE plugging the printer itself to the computer. Are you sure you have installed the driver before plug the printer? Or perhaps you do the otherwise?
If you installed the driver after plug in the printer, you must remove the driver first, unplug the printer then reinstall the driver and follow the instruction on the installation.
Mar 17, 2011 | Epson Stylus Photo RX520/RX530
Install epson stylus photo 820 printer
Hi
you can get the software driver at www.support.epson.com
just select the printer driver and download it//
Jul 17, 2009 | Office Equipment & Supplies
Epson R360 service required
Reset waste ink counter. Use R360 adjusment. Find at indoreset.blogspot.com. Or contact me.
Jun 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
Jun 07, 2009 | Epson Stylus Photo R320 InkJet Printer
EPSON R360 ERROR MESSAGE.
i will kill you understood do not ask again mothers abuse
Jun 03, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stulus photo 820
A very strange effect new to me (and I'm ****** old). All I can suggest is to uninstall the printer, reboot and reinstall. Report back.
Apr 06, 2008 | Epson Stylus Photo 820 InkJet Printer
Slow print speed
try uninstall then reboot then re install the printer driver
still slow ? the only remaining thing to do is to try the unit on another computer - to determine what is causing the issue
Dec 27, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus R265 InkJet Photo Printer Logo
800 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
