Iriver t60se One day, I was recording audio with my iriver T60se and it displayed a message saying that I had filled the memory. So I turned it off. A few days later, when I tried to boot it back up, it would not turn out. I changed out batteries, but nothing changed. So I slid the lock switch to the "hold" position, and when I pressed the power button, it displayed the lock icon and a message saying it was on hold on its screen. I can still drag and drop files to and from it when it's plugged into my laptop. How do I fix this?
  • L KG Nov 24, 2013
    Does anyone by chance have an image for the T60SE 2gb? I found a forum http://ubuntuforums.org/archive/index.ph... with advice on how to fix this problem in a normal T60, but I'm guessing that a T60 image won't work for a T60SE.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Remove some files to free up space and turn it on?
Posted on Nov 20, 2013
  • L KG Nov 24, 2013
    Hi bft_chromegu--Thanks for the idea. I tried this when I originally ran into the problem but even after I erased files the player won't turn on. I erased files that filled maybe 2% of the space on the player--do you think I would need to erase more?
  • 758 Answers
SOURCE: FORMATTING PROCCES...DOES NOT WORK FOR ME HELP!!!
You can Format your device by using the Sansa Media Converter, Windows Media Player, or manually through "My Computer". Best and easiest way is through "My Computer".
Connect your player. Go to "My Computer" > right click "Sansa e200" > drop down to "Format".
Or do it on Windows Media Player. Connect the player and open up Windows Media Player. Go to the "Sync" tab. Click on the arrow underneath it. Drop down to "Sansa e280" and then to "Format". This can only been done in Windows Media Player 11.
Or go to format under one of the options of the Menu Bar on the Sansa Media Converter.
http://www.sandisk.com/Retail/Default.aspx?CatID=1468 How-to videos. Look under "Sansa MP3 Player" option 8. "Windows Media Player 11" option 9. For how-to methods provided by sandisk on formatting.
Let me know if you need adtional help
P.S. Please rate accordingly
Thank You
Computerrep
Posted on Feb 09, 2008
SOURCE: Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
I called and they told me,i have the same problem, to just turn the battery switch ( bottom thing) off and charge it over night via wall outlet. hope it helps im trying it as i type so i wouldn't know...
Posted on May 19, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
SOURCE: iriver H10 "System files missing".
Okay, my IRiver broke with the same kind of problems but I've managed to fix it!
First off i connected the IRiver to the pc, and whilst it was connecting, pressed the 'select' button (the one on the front with the circle on it) to force it to connect.
Next i right clicked on it and selected format to wipe everything off it (just to make sure it was blank).
Next, go to www.iriver.com and on the left hand side click Support->Download and click on H10 in the product box. On that page should be a file to download called "[MTP]H10 5G/5G Pure/6G Firmware Upgrader/Recovery Tool(US & EU only)". The download icon is just underneath the title of it, so download, unpack using winrar ot winzip etc, then double click and follow the instructions.
It wiped the songs off, but i have an IRiver that works! Its an awful product in my opinion, but better to have it working than not. Can't guarentee that it'll work for everyone but it fixed mine first time.
Hope it helps!
Posted on Oct 20, 2008
SOURCE: Matsunichi MF326-256 "locked"
I had same problem, after not using it for years and losing the instructions which I had downloaded in 2005.
Then I recalled that plugging my earphones in might unlock it, and it did. I also plugged it into my PC to add and remove some files (but I don't think that had anything to do with it,
Try it. I have to say this site hasn't helped me as no-one seems to know the answers and google didn't help either!
I'd still like to get the instructions again. In the mean time I will press the buttons and cross my fingers!
Posted on Feb 09, 2009
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Messages deleted when phone is turned off
You must have cleared photos and videos. however, many people do not realize that an accidental audio recording can use up all the disc space. So check for extra large audio files.
Dec 30, 2008 | Samsung Blackjack SGH-I607 Smartphone
Iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
Sep 25, 2008 | iRiver H10 MP3 Player
Iriver X20 switches off when using FM Recorder
there may be a problem with the menu files...
Aug 30, 2008 | iRiver X20 MP3 Player
Iriver X20 database full
does the message stop you from using the iriver?
if it doesn't then there's a format function on the iriver in the settings menu...
if it does then there may be a problem with the usb connection...
either the iriver isnt responding or the computer can't read it!
for the user below there is most likely a format will fix it...
Aug 01, 2008 | iRiver X20 MP3 Player
Record reservation on Iriver T10 T60
check out the iriver h10 players
May 12, 2008 | iRiver T10 MP3 Player
Folders inside my IRIVER X20 no longer recognised!! HELP PLEASE!!!
Try making a new folder, under the same name as the ones lost, or missing. Since the X20 is flash memory based, you may have had some of your data go randomly corrupt. You MAY have to start things over. Sorry! Good Luck!
Apr 10, 2008 | iRiver X20 MP3 Player
Camcoder
you have to format phone memory of your P910 because some file is corruptet.Before you do this make a backup file on your pc to save your stuff.
Jan 13, 2007 | Sony Ericsson P900
IRiver ifp-700 record error
upgrade the firmware should fix the problem
Jun 26, 2006 | iRiver iFP-795 MP3 Player
107 people viewed this question
 Grubhead
Grubhead
