Question about Sanyo DP42841 42 in. LCD HDTV
Sound muffled The sound is muffled on the TV, mainly seems to be conversations are the worst, sometimes seems like background music on a show is louder than the conversation.
2 Suggested Answers
SOURCE: Sound imbalance
IS YOUR TV CONNECT TO SOUND SYSTEM LIKE COMPONENT OR AMPLIFIER. IF SO . TRY TO DISCONNECT IT. SO THAT YOU MAY KNOW WHO CAUSE THE TROUBLE. OR MAY BE YOU SET YOUR TV MONO.
Posted on Jun 13, 2007
Why does sound have a muffled sound to it
It sounds like you have a bad ground connection on either an input or output. Try wiggling the cables and plugs that connect to it. If you can figure out which cable is bad, try a new one. If it still has the problem, then the problem may be inside the mixer. If so, I can fix it. Contact me at ken_more@netzero.net.
May 13, 2014 | Mackie CFX20.mkII Live Sound Mixer
Loud background music/noise on tv
The cheapest, fastest, and nearly the best thing that I've found to create sound deadening is to hang rugs or tapestries on the wall where the noise is being made (best) and/or on the walls of the room where you are trying to deaden the noise (still good). Rearranging furniture so the noisy wall is more covered is also sometimes helpful. If the noise is below you, area rugs are best as wall to wall carpeting has been shown to not be as healthy.
Hope this helps
Mar 26, 2014 | Computers & Internet
Background sound often is so loud it drowns out conversations. Often occurs w=in a movie when there is some background music and dialog. Cannot hear the dialog. Has occurred when watching live music. ...
Looks like you have inadvertently enabled some sound effect, usually these effects can be enabled/ disabled form sounds menu. They will have names like surround, movie hall, concert etc. Go to the sound settings and disable any activated audio effects.
Mar 14, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
The background noise in a movie on Tv is so loud I can hardly hear the conversations. I have tried the audio menu. Normal, Wide, Low ..They all sound the same.
GO again into the customer menu and look for something that says Hall, Surround etc--I have seen this before--usually it is a setting that creates a problem where the background sounds are so loud you cannot hear the people talking......go thru every section of the menu--I be you will find this is your problem.
Let me know what you find--I am here to help people. I do not think you have a circuit problem--only some thing in the menu has been set to the wrong place.
If this has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 21, 2009 | Toshiba 42H81 42" Rear Projection...
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
Background sound too loud
Thank you, everyone! I thought maybe I was losing my mind. I can hardly watch a lot of the TV shows anymore due to the inappropriate use of music -- either it's too loud or there's just too darned much of it. Come on, TV producers! You are supposed to get better with time, not worse! Thank goodness I'm not alone.
May 30, 2008 | JVC AV-32260 32" TV
Check the audio settings. You might need to reduce the surround sound effect or increase the Center (dialogue)
Oct 21, 2007 | Protron PLTV-37 37 in. LCD Television
Sanyo DP42841 42 in. LCD HDTV Logo
48 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
