Question about Ovens
Whirlpool stove pf - Ovens
    Prodigy:
    An expert who has answered 500 questions.
  • Ovens Expert
  • 650 Answers
A pf code usually shows up if the power to the stove has been interrupted for a short time. It is usually cleared by setting the clock or setting the oven or broil.
Posted on Nov 20, 2013
My stove will not work it always shows PF how do I fix this as nothing works
PF is most likely power failure. Nothing responds in keypad? Try setting clock. If nothing responds, your control is probably bad.
Sep 16, 2017 | Ovens
Kenmore stove shows PF
PF .. means Power Failure
I would call company ASAP
But here are some sites, for a handy man
http://www.youtube.com/watch?v=BF-cmB9xBSk
http://www.youtube.com/user/AppliancePartsPros
Be safe .. sure hope your stove is up and running soon, so everyone can enjoy your good cooking
Apr 06, 2013 | Ovens
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 | Ovens
Power failure control panel beeps no lights on panel and oven wont turn on. have lights on inside of oven. do i need a code, never have before. always showed PF for power failure.
Was the oven doing a self clean when the PF occurred? If so the cavity limit probably tripped.
Sometimes the owner wants to shut down the process of self clean for whatever reason that also trips the cavity limit. If the oven circuit breaker is weak then their could be a power failure during which the oven was on and that could cause the cavity limit to trip. No lights on panel means the temp inside the oven control panel exceeded normal operating temp and the small inline fuse going into the control panel has melted:
This is what that small fuse looks like. To get to the insides
you usually drop the side trim exposing the screws then the controls fold outward.
Service manual for American stoves and more
Oct 23, 2011 | Whirlpool Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 | Ovens
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Had a power failure and now getting a PF E1 error on the control panel
F5 - E1 and E2 Check door/latch switch Replace switch if defective
It has detected a problem with the switch on the door lock motor. In most cases the switch will need to be replaced.
Nov 22, 2007 | Whirlpool GBD307PRS Stainless Steel...
Ovens Logo
218 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
