Question about Miele 30 in. KM443 Electric Cooktop
Cannot turn burner off
Red lights are still on after turning down minus all the way
I cannot unlock my fagor induction hob by pressing the plus and minus signs, what should I do?
check the keylock is not activated by holding down the key symbol for a period of 5 secs.
Nov 08, 2016 | Fagor Cooktops
My elements are off but the red light is still on?
Red light will stay on until burner temperature is down to a safe level.
Oct 02, 2016 | Frigidaire Stove/Oven/Range Black Glass...
Just moved in, used stove for the first time, a little red light won't turn off.
You might need to turn off the stove entirely. If there is even one function slightly on, the red light may not turn off. Try unplugging the stove if you can't figure out why its not off still.
May 22, 2011 | Jenn-Air JED8345 Electric Cooktop
Have a baumatic ceramic hob displayin letter 'L'
the solution is already on fixya i just tried it and it works.press the right key and the minus key at the same time release the right key hold the minus key for 10seconds and the L will disappear
Jan 25, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
Hob come on but all zones how the letter L in them and I dont know how to unlock it.
Pressed right bottom heat zone and minus button together and then minus button again to unlock.
Oct 18, 2009 | Cooktops
Heaters won't turn on
I would certainly call GE on this one!
Jul 24, 2009 | GE 30 in. Profile Select-Top JP389...
How do I turn cooktop on when All Off lock is iluminated?
Hold your finger down for 10 seconds on the red light. It will signal when lock is off.
Jun 04, 2009 | Jenn-Air JED8230 Electric Cooktop
Indicators
the 'L' means locked - to unlock turn on hob, hold down front right hand side plate control and minus botton to unlock - see manuals for further details
Sep 22, 2008 | Baumatic 23 in. B10 Electric Cooktop
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Miele 30 in. KM443 Electric Cooktop Logo
Top Miele Cooktops Experts
Dan Webster
Dan Webster
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
