The attention of a signal is 12db what is the final signal power if it was originally 4w
    Sergeant:
  • 330 Answers
If the original signal was 4 Watts, and the increase is 12dB, the increase is a factor of 16 which will give you 64 Watts as a final signal power. Power doubles for every 3dB.
Posted on Nov 20, 2013
What is the video single output VHF FM UHF 12db
That sounds like the description of a broadband amplifier. It likely has "F" type (cable-coax) connectors and a power cord.
Commonly used to increase the signal level of TV cable to compensate for inserting a signal splitter, or in some cases to increase the signal level from an antenna, typically outdoor TV or FM radio antenna, so it is connected between the signal source (antenna, or cable) and receiver with antenna as input and receiver connected to the output of this little box. The gain (amplification) it provides is 12 dB, so the output is more than 3 times the input.
Oct 03, 2014 | Radio Communications
4x4 dont work
you have 4w low.. low/lock..4w high and hi lock..4w low is just a slower set of gears that gives the truck way more power for like pulling or towing in harse conditions.. 4 w hi is more for traction at hyway speeds..you may have a seperate lock lever.. most do..
Jan 03, 2014 | Cars & Trucks
I have an old motorola mobile 40 channel cb radio T4022A can you tell me wnere and specs on this unit?
Local-Distance switch for selective signal control. Modular filter board design for easier maintenence. LED Channel readout. Power Microphone. Automatic noise limiter. 3.5" speaker. Integrated antenna mismatch protection. Signal RF meter. 4W RF power. 12VDC.
Jul 10, 2010 | Car Audio & Video
I have a zebra 2844 - it finally prints the right label size and all but skips lines on the label. HELP PLEASE!
It is because you do not have a factory original power supply. If you watch the printer or power light on the power supply I would bet it turns off and then back on again. Don't pay attention to the power supply specs they can be weak. Get a Hitek Plus 120 or 220 or FSP50-11 it will work. Good Luck.
Apr 07, 2009 | Zebra LP 2844 Thermal Printer
What are the correct spaekers for the gm 5100t ?
    CEA-2006 Compliant Amplifier Power Standard:
  • 125 Watts x 2 @ 4 ohms <= 1% THD+N
  • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
  • 75 dBA Signal-to-Noise Ratio
  • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
  • 2 Channels
  • Continuous Power @ 4 Ohm: 125W x 2
  • Continuous Power @ 2 Ohm: 190W x 2
  • Continuous Power Bridged @ 4 Ohm: 380W x 1
  • Frequency Response: 10Hz-50kHz
  • THD (1kHz, 4 Ohm): <0.015%
  • Signal to Noise Ratio: >95dB
  • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
  • PWM Regulated MOSFET Power Supply
  • Balanced Isolator Input Circuit
  • Oversized Screw-Type Power/Ground Terminals
  • 2 Channel RCA Inputs
  • Speaker Level Input
  • Screw-Type Speaker Terminals
  • Hi-Volt Input Level Control (200mV-6.5V)
  • Bass Boost (50Hz, 0/6/12dB)
  • Selectable LPF (80Hz, -12dB/Oct.)
  • Pioneer 1-Year Warranty
I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
Cobra 25 LTD - building causing a shadow area
The older base station was probably peaked and tuned by a CB shop, basically giving it a lot more power. Stock radios very rarely have a full 4watts of power, to tell you the truth. Mine now does 5 1/2 watts and swings to around 20 when I talk. Might be a good investment. Oh, the antenna can't be too big for any wattage. Might want to recheck the antenna's tuning, though...
The truckers wont pop the fuse at all, but I might recommend backing your RF gain down some when they are that close so they dont burn up your receive.
Jan 14, 2009 | Cobra 29 LTD CB Radio
V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Aug 14, 2008 | Car Audio & Video
B&W PV1 Subwoofer
Make sure that your amp is putting out proper signal to the sub woofer.
If the feed from the amp is okay, the power amp and our the power supply in the sub woofer may have become defective. This will require to be serviced.
Jerry G.
Jun 13, 2008 | B&K AV 125.7 7-Channel Amplifier
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
