Computers & Internet Logo
Louise Marshall Posted on Nov 20, 2013
I have an old Print Shop 6.0 OEM Special Edition I have been using forever. I have Vista premium It just quit. I uninstalled it but it won't reinstall. It says "product identification file is missing or damaged. Reinstall" I am a senior and don't want to learn another version. I love this old one. Help.
  • Louise Marshall Nov 20, 2013
    I am the administrator, it won't install so there is no desktop shortcut. I hear the CD running then it just quits.
Jeff Boles
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Nov 20, 2013
Jeff Boles
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
7204
Points
56
The program must be installed in an Administrator account and must be run in compatibility mode.
To check if you are using an Administrator account use the following steps:
1. Click on Start, then Control Panel
2. Open user accounts then select your Account
3. If it says Administrator you are finished, if not continue to step 4
4. Select Change your Account type, then choose administrator.
5. Click Ok.
6. Reboot computer and install.
Once the install is complete, follow these steps to run in compatibility mode:
1. Right click on desktop shortcut, then select properties
2. Click Compatibility tab, then check the box that says Run this program in compatibility mode for:
3. It should default to Windows XP (Service pack 3). leave it there.
4. Click Ok.
This should resolve your issue. If it does not, either you have a bad install disc or you will need to perform a completely clean install of Print Shop, which is signficantly more involved.
5 Related Answers
Anonymous
  • Posted on Aug 29, 2008
SOURCE: java install 1101 error
Download Full Manual Install here
http://java.com/en/download/manual.jsp
Disconnect your internet. Then install. Works like a charm now. I had the same issues with Vista. :)
Anonymous
  • 827 Answers
  • Posted on Dec 15, 2008
SOURCE: unable to uninstall Photoshop 7 on Vista
Try deleting all the files from the Photoshop folder in the Adobe folder in Program Files.
Then download a free program called ncleaner. just type ncleaner into google. after you install it, run it and press the Clean System button, then Clean Now. Just click yes when it asks you. Then click back to the main screen, and click find junk. that should get rid of any leftover files from the photoshop install.
chris
Anonymous
  • 702 Answers
  • Posted on Apr 23, 2009
SOURCE: problem installing Scansnap S510
This is probably due to the program using the same folder for the new version of the program. Best solution would be to uninstall the new version, uninstall the old version and then reinstall the newset version only.
Running a registry cleaner in between does not harm.
One other thing to try is an uninstall program, but I am not sure that will help.
Anonymous
  • 144 Answers
  • Posted on Jun 05, 2009
SOURCE: the certificate file is missing or has been
i would call wherever you got that cd and get a new one there must be files that are missing on there... it could happen
Anonymous
  • Posted on May 16, 2011
SOURCE: Apple Application Support was not
How did you uninstall itunes? If you run into an error, or your computer while your itunes was installing, it could leave things behind messing up all the other installations as well. What you need to do is first of all make sure you don't have any instances of itunes open, or trying to be opened. Then you can go ahead and run the uninstaller on itunes.
Then you will need to go into explorer (windows+e, or right click on your My Computer icon and press "explore" from the menu), navigate to C:\Program Files\ and delete the itunes folder completely. If you get an error saying something to the effect of "This file/folder is being used by another program, please stop that program and try again." go ahead and restart your computer, and try to delete the folder again when your computer comes back up.
Then try and reinstall it, making sure that you are downloading the correct version of itunes for your operating system.
I have an old Print Shop 6.0 OEM Special Edition I have been using forever. It just quit. I uninstalled it but it won't reinstall. It says "product identification file is missing or damaged. Reinstall" I...
5. Click Ok.
Hi there, My adobe photo shop album starter edition 3.0 has expired, I can't get through to the adobe helpline and all my photos are inaccessible. Please help!
REMOVE IT WITH YOUR UNINSTALLER 2010 AND INSTALL IT AGAIN FROM THIS LINK YOU WILL FIND ALL ADOBE PRODUCTS ftp://ftp.adobe.com/pub/adobe/
How do I get XP files I haved saved to print on my Vista system? When I download old xp files to vista they're blurry and they print blurry.
It should not matter
Try checking your printer
See if there's still enough ink on it to print.
You can also try to clean the ink cartridges nozzles
3helpful
3answers
My Acer aspire x3200 Home Premium will not let me upgrade to windows 7 home premium.Installation failed.
Sometimes you're better off to uninstall the old OS, and then install the upgrade. If you have files to save, store them on removable media, then format the drive, then install the upgrade. During the process, it will ask for the VISTA product key, and the windows 7 product key
I need to get back in my OEM vista home premium
If you contact Toshiba, they can send you the original restore disks. If you are really nice to them, they might send them out for free.. I believe normally they do charge but they sent them to me for free a couple of years ago with my Toshiba laptop :)
Print Shop 23 appears to install, but never finalizes
The fact that MS Net 1.1 framework is compatible with the 32-bit version of Vista - because I am using Print Shop 23 on my 32-bit version of Vista.
However, Print Shop 23 is not supported on the 64-bit version of Vista. and MS Net 1.1 framework is not compatible with the 64-bit version of Vista. So, I would guess that you are using a 64-bit version of Vista.
I have heard that one way to work around compatibility issues with MS Net 1.1 framework is to make sure you have the latest update installed for MS Net 1.1 framework. But, since I'm not sure that that is the only recommended fix for your problem, the best thing for you to do would probably be to click on this link
http://forums.encoreusa.com/tm.asp?m=24071&mpage=1&key=%E5%B8%87
To find quick answers to Frequently Asked Questions about Encore and Broderbund products, please visit Broderbund's new Product Support web site at:
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
3helpful
2answers
Can not get Print Shop 23 deluxe to install with Vista
During installation you must explicity tell the installer to install the Art Content. Had the same problem. Reinstall 1st CD and then choose modify and then choose all Art content.
Printing from Elements 6 w/ HP 8250, image pushed to left.
I wish I did have a solution. Photoshop Elements 7 exhibits the same problem. They obviously broke something. I have to use an old version of Photoshop Elements 4 just to print properly. I am a tech support professional, uninstalled all HP software, re-installed latest drivers and problem persists. Sucks.
3answers
Product key (25-symbols) for windows vista home and student 2007
I am sorry but you have to purchase the MS off ice package from microsoft.  Your product key you are refering to is for the Windows program only.  We cannot provide you with a key as it is considered software piracy.
Grand Canyon Tech
Grand Canyon Tech
