Complex sentance exaples of a complex sentance
Use password and forget
Try usuing a simpler password which you could easily remember. For exaple, ABC123... is a good one.
Feb 13, 2013 | SanDisk Microsd 2gb Memory Card Micro Sd 2...
How do I get rid of blue lines under my sentences
If you are getting a line under your sentances its one of two things. Either you have the underline button on word or whatever other word processing program you have been using on OR the word processing program is trying to tell you that there is a problem with your sentance structure. You will need to re open your word document and make correction then reprint.
Jun 22, 2011 | HP Color LaserJet 2600n Printer
Where can i download free driver for this?
free driver download for this?
see the manufacturer exaple hp open example google type hp the navigate to example hp site for driver
Dec 02, 2010 | Office Equipment & Supplies
Curser problems and more!
check your mouse settings in Control panel, adjust accordingly...
Oct 06, 2009 | Dell Inspiron 2650 Notebook
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
Raymarine st8002 wired to furuno
The st8002 is not compatble with rs232 data. You need to supply it with nmea 0183 data. You will need to wire it to the "NMEA port IN" on the pilot to NMEA out on your Furuno and turn on the mnea sentances "out" on your Furuno. You will need to turn on at least the following sentances GGA GLL RMB RMC.Hope that helps.
Apr 20, 2009 | Raymarine St8002 Smartpilot Autopilot...
I need a good picture of olympus e500 dslr evolt
You can check for exaple internet http://www.steves-digicams.com/2005_reviews/e500.html and you get a full review as bonus. By the way I have this remarkable piece of foto equipment. I rate it 5 strars!
Echo007++
Apr 27, 2008 | Cameras
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
