Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Omega DW401XA-1 overfill alarm wont clear after drain unblocked
Unplugged dishwasher for 24hrs. 1 year ago alarm cleared after 3 days unplugged. Why?
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
yalmer
  • 552 Answers
SOURCE: SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Posted on Apr 30, 2008
ginko
  • 19396 Answers
SOURCE: Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Posted on May 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: Dishwasher won't drain. Floods out onto the floor.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 22, 2009
  • 457 Answers
SOURCE: my bosch exeel dishwasher gets stuck on rinse at
change the control module. im a old bosch tech. send me a 4thumbs post if this was helpful
Posted on Feb 28, 2010
Stuck in drain cycle
Hello Vicki. If the drain pump sounds like it is running and will not shut off, you are on "flood mode" There is standing water in the bas pan of the dishwasher. sometimes water can get down there due to an overfill, or not draining completely between cycles. You can either wait for 2 or 3 days and the water will evaporate and should run normally. You can remove the bottom access panels and either vacuum out of dry the water (REMOVE POWER FIRST !) . If it does not clear on its own or if removing the water manually does not work, then the float switch will need to be replaced that activates the flood mode. There is a small possibility you have a bad control .
Apr 09, 2014 | Viking DFUD142D Built-in Dishwasher
Electrolux ESI 6180
I was shown how to clear your dishwasher and keep it running much longer. however, be careful when doing this. start with an empty dishwasher. pour 12 cups of cold water to the bottom area of tub and wearing latex, or rubber gloves, measre and por in exackly 2 cups of ammonia. let that solution sit there either all day, or overnight, at least a few hours, then run it through your machine, do not add anything else. do not do this with small children around. if you prefer buy the largest jug od vinegar (white) and pour it full strength into tub of your macine. let stand sevral hours, then put through a light or regulsr cycle. if you encountet that same problem empty, press drain cycle. retry usingrinse cycle instead. let me know if his resolnves your problem.
Nov 15, 2013 | Electrolux Dishwashers
Dishwasher error code
The manual shows there are 3 possible causes of the alarm
1. water supply is not there
2. drain time is too high - possibly a blockage in the kitchen sink drain
3. the water overfill in the base.
Most likely the cause could be 2 or 3. If kitchen drain is clear then the reason could be a faulty overfill switch at base of dishwasher assuming there is no water collected at the base where the motor and pumps are located.
Jan 04, 2013 | Dishwashers
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
Dishwasher blockage...not washing
It sounds like the pump is bad. Unplug your dishwasher, pull it out and check to make drain hose is clear.
Dec 17, 2017 | Neff 24 in. S5443X2 Built-in Dishwasher
Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Leaks, doesnt drain properly and cloudy film on glasses
u have water under dw .and overfill switch turninng on only  drain pump all time.second from bosch water  water never leaks on floor.
Sep 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
WHIRLPOOL TOP LOADER OVERFILLING WATER
While it is filling up try this. Unplug the washer from the wall, if the water still runs then you need to replace the mixing valve. If the water stops then take the screws out at the base of the console and flip the controls back. Look for the clear hose that goes to the water pressure switch and make sure that it is connected. If it is connected take it off the switch and blow through it to see that it is clear of any obstructions.
If this only overfills after the first ore second wash then you may have the slow drain and the drain hose is in the downspout too tight.
Possible items needed;
#1 mixing valve
#2 pressure switch
#3 plumber
Jan 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Not draining...hose clear
not really, it sounds like you have done all the basics,
Oct 09, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
70 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
