Question about Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner
Rinnai 556 WT gas space heater flashing PF - Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner
  • 739 Answers
Most modern gas heaters use a code system to tell the operator what the problem is. look for a pattern in the flashing, and then compare that pattern to the literature on the inside of the heaters panel. When you have a diagnosis code, you can follow the appropriate course of action.
Posted on Nov 20, 2013
5 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Posted on Jul 29, 2009
SOURCE: Rinnai 556 Heater
Call Rinnai. I have replaced about 15 control boards that have an issue rating with the capacitor microfahred rating. There is no recall, but if you at least let them run your EXACT MODEL AND SERIAL number you may be pleasantly suprised that they send someone out to replace the board.
If you have a dual port digital manometer and are handy, you may be able to install a new board. You MUST reset the high and low fire rate with the new board. Hope this helps
Al
Posted on Sep 25, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai propane heater Model RHFE-556 -
Yes, there is an Eprom setting that should hold settings up to 48 hours. You can find a manual by going to www.rinnai.us.
Posted on Nov 03, 2009
  • 66 Answers
SOURCE: Rinnai energysaver 556 wt. propane heater stopped
Check your filter ,and clean it. A system must be able to breath.
Posted on Feb 16, 2010
My rinnai 556 will not start, the only light is with the child lock pressed, on/off does not light? any ideas?
HI, Dear your rinnai 556 is not starting thats why it can not genrate the error code ,i advice you in this case you can not identifiy the exact problem. but i m trying to help you with my best tring:-
What you need to do -
Check the model number and serial number which are found on the data label located on the bottom of the right hand panel of the unit. Any Rinnai Energysaver Models RHFE-556T and RHFE-556FTRG Gas Air Warmers with a serial number contain the the year (YY) digits "00" to "07" may be affected. If you cannot read the data label or think you may have an affected model do not use the Air Warmer and inform anyone who may use the Air Warmer that they should not do so. Contact the Rinnai freephone helpline for further instructions, even if you have not experienced any problems
HELPLINE 0800 0304 556 or you can visit http://www.rinnaiuk.com or email project@rinnaiuk.com if you have any further questions.
The helpline staff will validate whether you have an affected product and will arrange for a Gas Safe Registered Engineer to visit and replace the gasket in the air Warmer.
i hope this will be helpfull to you. PLEASE DON'T FORGET TO VOTE ME. GOODLUCK..............
Jan 21, 2011 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
What does it mean when the power light (the small round light on the front of the heater that indicates the heater is on) is red instead of green?
was reading a rinnai pdf today about this, green means that the unit has power the red means the burner is operating so it just tells you when the gas is going basically, may not be the same for this rinnai model but is on the energy saver 556 so hopefully that explains your heater for you it should be in the owners manual if you have one as pdf i was reading was manual for another rinnai if you don't have a manual you can try downloading just type heater name and model into your google search with manual mentioned there too should bring up a pdf or a link to manual
Nov 16, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
We want 2 energysaver K556 space heaters fitted in our home. We already have a Gas Meter. What would it cost us?
Install costs vary hugely depending on length of pipe run to each heater (copper pipe is sooooo expensive now) Find a good (recomended) installer. Quotes are always free and really the only way to asnwer your question accuratly.
Apr 23, 2010 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
Our heater seems to have therostat set low. We are cold.
not sure if this unit has any type of sensor to protect you from carbon monoxide but if it is ventless and operates on gas it may be tripping on sensor any ventless unit must be operated with fresh air for combustion
Apr 06, 2009 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinnai 556 Heater
Al
Feb 10, 2009 | Rinnai EnergySaver 556 Air Conditioner
Looking for Manuals
Google rinnai 1004 and 556 manuals. I just did and found them
Nov 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner Logo
254 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
