Question about LG Televison & Video
Cannot get local channel 8 for NBN Central Coast.
How do I tune manually for this programme ? Reset and auto tune does not work. All other 44 channels are okay. Channel 50 appears for NBN but no picture.
    Problem Solver:
  • 13 Answers
Try my switch.digitalready.gov.au to locate the channels numbers to manually tune.
Posted on Nov 21, 2013
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
SOURCE: sony trinitron kv-x2982u - how do I tune a channel in?
my sony trinitron wont turn on, its just come back from the repair shop and they had it up and running for 2 weeks. it came on breifly then went back to not turmnning on useing to remote.
Posted on Feb 09, 2009
SOURCE: LOST PICTURE & SOUND - UNABLE TO RE-PROGRAMME
i have a technika lcd26 207, the power button works and the light comes on, but i have no picture or no sound, just a complete blank, black screen. any suggestions please?
Posted on Mar 16, 2009
emissionwiz
  • 79077 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Posted on Jul 28, 2009
SOURCE: Channel selector does not work; can not auto tune
Sorry not be able to solve the problem. I have exactly the same problem. So it is not related to anything you've done. Something faulty in the TV. It happened after 1.5 years in my case. Any tech support link appreciated
Posted on Jan 12, 2010
46xbr kdl hi for some reason my tv as froze on channel 44...it is set in the programs list and i cant remove it...
you could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 03, 2013 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Need to scan channels
you can do the auto search channel. just press the tv menu and then find the channel search and select auto search. so that all available local channel will tuned.
Aug 30, 2012 | Insignia NS-LTDVD19-09 LCD TV
I have inadvertently mistuned in my tv and some programmes are not there now.Please advise how to re-tune my tv as the HD is no longer on it. Thank you.
Simple way to do is automatic tuning.Press Menu, go to Channel set up (Programme), select Auto Tuning. Your available channels will be set up in order of their channel numbers. Later you can shift the channels at desired programme number.
sonsunny
Jun 18, 2011 | Sony Televison & Video
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
I am in Afghanistan, Kabul Area. I have an ALT2260M Avol tv. when I use the autotune for channels, All I get are the local channels. We are hooked into the AFN Network cable and it does not pull those...
try going into the autotune then select us then cable select the auto acan then change from auto to irc or std then scan should do the trick.
Dec 06, 2010 | Televison & Video
12 channels are turned on the rest have been deleted, how do I turn them back on?
Hello
Go through your TVs operation manual. and set it to auto tune. It will regain back all the channels cleared after the complete tuning process. Wait for to tune for all bands. Never interupt the process until search process ends and displays the first programme got by it on the screen. Ok.
Nov 26, 2010 | Sanyo AVM-2507 25" TV
New Sharp 32" LCD HD TV. Supplier correctly installed and tuned in. Advised me how to select TV or INPUT when tuned on using TV /Video button Then select channel. I did this successfully, but later had...
Does this particular television have a digital tuner built in? If this is the case, try to search for your channels. There should be a section in the manual for this. If you have an external tuner, check and make sure you have the correct input selected and then change the channels on that device rather than the television.
Dec 16, 2009 | Sharp Televison & Video
Tuning programmes on Toshiba 30HF83 30" TV Problem
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Sep 03, 2007 | Toshiba 30HF83 30" TV
Televison & Video Logo
76 people viewed this question
Computer Repairing
Computer Repairing
