Question about Konica Minolta bizhub Office Equipment & Supplies
Konica 7030 open conveyance cover 6 fix unit - bizhub Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,680 Answers
The hot part check for broken acturator for cover 6. due to heat over years might be broken
Posted on Mar 11, 2018
5 Suggested Answers
  • 6 Answers
SOURCE: Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
Posted on Aug 09, 2008
Cogz
  • 1326 Answers
SOURCE: My Konica 7020 nmakes a slight grinding noise when
Most likly, you have a broken or you have a fuser driver gear that is missing a tooth from it or the gear is worn out. The problem could bee that the ball bearings in the fuser unit have stoped turning or not turning correctly.Causing the drive gears to fail.
Posted on Mar 23, 2009
  • 48 Answers
SOURCE: Paper jam
I strongly recommend a service tech. It sounds like you will need a PM kit,fuser claws and a few DFP rollers.
Posted on May 29, 2009
hattinghbr
  • 214 Answers
SOURCE: a konica 7030 displaying a meassage " remove paper from the exit tray" on the screen, how do i fix it? tnx
check if there is a paper at your exit feeder try. at the fuser.
if not. see if the paper sensors are not stuck.
Posted on Nov 15, 2011
Where is the fns conveyance door on a konica 7020
Open the finisher should be to you up & right it would be where the paper comes out of the copier and into the finisher between both units is the conveyance
Jul 22, 2014 | Konica Minolta Office Equipment & Supplies
My knocia 7222 is always jamming it says open right side cover release lever 1 and remover paper open conveyance cover 6 fix guide 5 during depress fix guide 9 remove paper the paper always get stuck by no...
close right side cover is showing on the screen display but door is closed i have already replaced the door switch and power supply board and main mother board and tray control board.kindly advise what can i do to remove (close right side cover) sin?
Tariq E-Tech E-Mail : e_tech_pk @hotmail.com
cell : 03455235670.
Mar 15, 2013 | Konica Minolta Minolta 7222 Laser Printer...
A konica 7030 displaying a meassage " remove paper from the exit tray" on the screen, how do i fix it? tnx
Nov 15, 2011 | Office Equipment & Supplies
Konica 7222 f28-3 code
part # for the t/s unit is 40la-2600. if you need it I can order the part for you
Aug 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
F 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
May 11, 2009 | Office Equipment & Supplies
My Konica 7020 nmakes a slight grinding noise when printing and then it stops and says open conveyance 6 fixing unit guide 5 and remove paper. Thanks Randy
Mar 21, 2009 | Konica Minolta Office Equipment & Supplies
Paper jam
Mar 21, 2009 | Konica Minolta DiALTA Di200 Copier
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
