Question about Plumbing
AcquaSource quarter turn faucet Model # FW0A0001NP Dripping Problem
This quarter turn faucet is fixed wrong. The quarter turn off position starts the water and quarter turn on position stops the water. Also this faucet is dripping. The faucet is 1 month old. How I can fix these problems and set the on/off position correctly ?. I lost the instruction manual. Please help.
  • 659 Answers
SOURCE: dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Posted on Mar 16, 2009
  • 68 Answers
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Posted on Apr 12, 2009
  • 49 Answers
SOURCE: My Moen kitchen faucet stopped working suddenly in
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Posted on Sep 03, 2009
  • 145 Answers
SOURCE: Hi Guys, We had problems with our kitchen faucet
hey has to just reset the handle ok
Posted on Jan 10, 2010
motor1258
  • 6674 Answers
SOURCE: how do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Posted on Jan 22, 2010
Fix a dripping single handel moen faucet
you can go on line with the make
Nov 11, 2013 | Moen Plumbing
Dripping water unless I totally shut off cold water line.
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 29, 2013 | Kohler K-12265-4-CP Fairfax Widespread...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Faucet dripping
Call Price Pfister at 1-800-PFAUCET and ask them to send you a new hot and cold stem for free. These faucets are easy to repair. Here is the parts breakdown for your faucet. Turn the water supply of to the faucet. Remove the index button from the top of each handle. Unscrew the handle retaining screw. Pull the handle off. Unscrew the stems with an adjustable wrench; turn them counterclockwise. Install the new stems and reinstall the hanldes; it may take a couple of times to get them set in just the right positions. Slowly turn the water back on and open the faucet.
Sep 05, 2010 | Price Pfister Savannah Two-Handle Kitchen...
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
Jun 30, 2010 | Delta Model 470: Signature Kitchen...
How do I fix a dripping MOEN T4572 lavatory faucet
No charge.
Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
My faucet is dripping--is there an easy fix, or
you could aoways go to there web site alot of these type of faucet have real good warrantys you might just be able to get a replacement for free,,, depending on the age of the unit
Jun 27, 2009 | General Electric GE SmartWater Household...
Dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
Mar 14, 2009 | Kohler Model 102704A: FortĀ® Centerset...
Plumbing Logo
99 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
