Question about Bladez Exercise & Fitness
Need to reset computer
Need to reset resistance too high
How to tell if my bulb needs to be reset or bulb needs replaced on my panasonic pt50lc13
easiest way to check any kind of bulb is a multimetre on resistance across the contacts open cct ie very high resistance and wire has broken. hardly any resistance 0 to 1 ohm and its finecoil still got it together
May 04, 2018 | Panasonic Televison & Video
How do get rid of F10 which is on the window of my Kenmore stove
The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
Feb 04, 2015 | Kenmore Ovens
I need to reset my diagnostic link connector for my 1995 Oldsmobile Aurora. But whenever I plug my tools into it the tool says that its not connected to the computer so I'm thinking there is a short or...
No clue, either, so to start I would check the validity of the wiring from the computer to the diagnostic connector. Find a wiring diagram and get out the old trusty ohmmeter. You know where the computer and the diagnostic connector are.
Take off the negative battery cable. Pull the PCM connector off. From the wiring diagram you know what pins on the PCM connector go to the diagnostic connector. Now, one ohmmeter lead on the diag. conn. and the other meter lead on the PCM connector-turn the meter to ohms and see if very little resistance is in that wire. Resistance to current flow means very high ohms. A short is a break in the wire, and the ohmmeter will show infinite resistance. A wire still connected by two little strands with the others broken, will show very high resistance, just not infinite.
Check all the wires going to the diagnostic connector in the same way. If all wires are good, check the computer is getting fully powered. Is check engine light on with key on? Is your diagnostic tool working okay on other cars?
Sep 11, 2013 | 1995 Oldsmobile Aurora
Has any one had problems with bosh oxagen sensor not working properly
Hi there:
Are you buy same or OE part replacement according with the Hyundai part number catalogue? This is important. Keep in midn that you need reset or delete all previous code stored in the car computer.
DTC P0131 - Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 1)
Essentially the same as P0136 and P0137, a P0131 code refers to the first oxygen sensor on Bank 1. P0131 means the O2 oxygen sensor's voltage remained low for longer than 2 minutes. This, is interpreted by the ECM as a low voltage condition and sets the MIL. Bank 1 Sensor 1 is located in front of the catalytic converter.
There may be no visible symptoms to the driver, other than the MIL (Check Engine / Service Engine Soon) illumination.
A code P0131 may mean that one or more of the following has happened:
- Faulty o2 oxygen sensor
- Short to voltage on O2 signal circuit
- High resistance or open on O2 signal circuit
Possible Solutions:
- Replace faulty sensor
- Repair short, open, or high resistance on o2 signal circuit
Now, about DTC P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
A code P0135 may mean that one or more of the following has happened:
- O2 Heater element resistance is high
- Internal short or open in the heater element
- O2 heater circuit wiring high resistance
- open or short to ground in the wiring harness
Possible Solutions
Repair short or open or high resistance in wiring harness or harness connectors
Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 17, 2012 | Cars & Trucks
My oven is self-cleaning mode...it is beeping and flashing f-2. How do I stop or reset?
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
thats what a F2 code is on a GE
Jul 15, 2011 | GE Profile JK915 Electric Single Oven
My 2006 Town car has climate contr4ol but the fan only works on high speed. How do \i fix it??
More specifically it is called the blower motor resistor... Usually located up against the firewall behind the glove box area... Where ever you hear the fan spinning its usually close by... Usually looks like a flat computer board with inline capacitors..
Dec 17, 2010 | 2006 Lincoln Town Car
I have a OM-22 and the high limit switch shorted out. Do you know where i can get one? And I have no lights on the control panel, is this normal or is there more damage? deyoung@tds.net
When your heater overheats the high limit should open (ie. infinite resistance). This shuts down the heater and gives an EE12 code. When the heater cools, the limit should reset itself (no resistance). Then if you haven't already turned the heater off, turn it off and then turn it back on and it should go. If the high limit doesn't reset, you can google Toyostove dealers and they should be able to get you one. I have also sent you an email. You should also make sure the fan cage is clear and that nothing else is blocking the air flow.
Oct 08, 2010 | Heating & Cooling
How can i adjust the resistance other than from the console. It will not adjust from a very high setting...the console shoes number 1, but it will not adjust no matter what i press. Thanks
unplug the unit for more than an 1 hour then pung back in. this may help reset the magnetic motor. If not you need to replace batteries in the computer as well and let sit for hour before putting battiers back in. This may do it. If not you will needto have the magnetic motor replaced
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Oct 03, 2009 | Exercise & Fitness
Diagnostic Code P2074 on 2007 PT cruiser-can't find on OBD list.
P2074-manifold Pressure/throttle Position Correlation
CORRELATION - HIGH FLOW/VACUUM LEAK
When Monitored: Engine Running, during all drive modes.
Set Condition: If vacuum drops below 1.5 Hg with engine RPM greater than 2000 RPM
at closed throttle.
POSSIBLE CAUSES
VACUUM LEAK
HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
MAP SENSOR
HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT
HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT
PCM
TP SENSOR OPERATION
HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
TP SENSOR
HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT
HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT
Mar 27, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
Exercise & Fitness Logo
15 people viewed this question
Top Bladez Exercise & Fitness Experts
gbob59
ray gallant
Tom Chichester
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
