Question about Dyson DC28 Animal Vacuum
Brush bar is not spinning
Vacuum turns on, and sucks. however the brush bar does not spin and it makes a loud clicking noise when pushed.
    Top Expert:
  • Dyson Master
  • 33,320 Answers
Common causes of brush roller failure are belt breakage and clogging. If this is a Dyson animal vacuum, you may find the brush roller is so clogged with hair that it cannot rotate. The solution is to remove the brush roller and clean it thoroughly, particularly inside the end caps where hair accumulates. It is unlikely that an entire animal was ingested.
Posted on Nov 20, 2013
2 Suggested Answers
austyn_goodm
  • 17 Answers
SOURCE: Dyson DC41 brush won't spin
You need to check the belt hooked to the side of the brush (sometimes hidden by plastic)
Posted on Jun 26, 2012
Why is my hoover spin brush making a loud noise when i turn it on
Check for clogs starting with the air passageway at the bottom.
A piece of TV cable or similar works well as you have to snake
it in. Check all hoses, Are the filters clean? If you can, remove
the brush bar and belt then turn vacuum on. If the vacuum is
no longer making a loud noise the side bearings on the brush
bar are the problem...replace the bar or spray a bit of WD40-
if you do that wipe well before you vacuum. Finally....if the
vacuum was still loud with the brush bar off...you have a motor
problem and that could be expensive.
Regards.
Dennis
Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Motor loud
The beeter bar bearings are bad i just changed the beeter bar on a vacuum that fixed the loud noise check for play in the old beeter bar brush
Mar 21, 2014 | Eureka 4700A Maxima Bagless Upright Vacuum
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson Absolute has started making a loud noise and the has gotten progressively more difficult to push. I'm guessing the self-propel has stopped working. Is there a quick fix?
Hi its Darran at Dyson.
Try making sure the brush bar is turning when in the vacuuming position. It is possible that the brush bar is obstructed which can cause your machine to make this noise.
Check out our online help at www.dyson.co.uk/support.
Kind regards
Darran
Dyson Customer Service.
Apr 13, 2010 | Dyson DCO3 Absolute Bagless Upright...
Very loud click/catching noise - Dyson DC07Allergy
Take the sole plate off the brush bar (with a coin or a screw driver)compartment and check for blockages near the brush bar and make sure the brush bar spins round freely.
Its sounds like the clutch is slipping (it does this to protect it self from burning out when something is stopping the brush bar from turning)
A quick test is when in upright position turn the brush bar knob to off
(usally in drive postion) then try the user position again - the brush bar should not be turning and they should be no noise
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vibrates very loudly when brush starts spinning
take out screws on bottom and see if tension bar can be tightened, make sure the right belt is in there, also if belt looks worn or gouged replace with a new belt
Apr 23, 2009 | Vacuums
Dyson DC14 Animal Vacuum - terrible loud noise
I have purchased six Dyson DC14 vacuums on eBay at rediculously low prices as they were being sold "as is" because they made a "terrible noise" when the brush bar was engaged. Each of the vacuums I received were like new, literally, and did make the terrible noise that was described. For less than $25 each, I purchased replacement beater bars (brushrolls) from an eBay seller in England and ALL six of the vacuums work perfectly.
When I dismanteld each of the units, some beater bars only had hairline cracks and and others were falling apart. I first purchased beater bars from eBay that were very cheaply made and broke within one or two weeks. The beater bars I got from England have been going strong in a commercial business for over a year now. That's equivalent to 5 years use in a residence.
Defective beater bars are more frequent than most people realize. I'd lay odds that is your problem but you will never know until the beater bar is removed and closely inspected. Some fractures of the plastic can be hard to see.
Hope this helps.
Mar 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bar doesn't turn unless vacuum is pushed.
Oh for crying out loud! That button has been there since day one but I NEVER looked at it! I guess I thought is there to be symetrical! I also sucked up carpet thread. I was okay for a while but when I then sucked up my dustcloth the brush quit. Usually this stuff happens right before the guests are due so at least this time I got to fix it without pressure!
Apr 05, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
http://dysonmanuals.inc.io/
Oct 14, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC28 Animal Vacuum Logo
326 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
