Question about Bissell Pro Heat 2x Select Pet Upright Deep Cleaner
The brissels wont rotate - Bissell Pro Heat 2x Select Pet Upright Deep Cleaner
You have a jammed mechanism or a broken belt
Posted on Nov 20, 2013
Why when i just installed a new T104 timer yet seems wont turn on with pins
Are you sure that you put the pins on right? They have little projections on the bottom that turn the timer on/off as the cam moves through its 24 hour rotation. The little gear in the back is connected to the motor and because it is spinning that tells you that the motor is definitely good.
Sep 11, 2015 | Intermatic 220v T104p Swimming Pool Pump...
How do I install my hot water heater?
Youtube offers many videos of the water heater installation. Drain first with a garden hose. after turning off water and unplugging electric or shut off gas.
If changing to a tankless, remember they often require a larger vent pipe to the roof. 4" usually, not the 3" for tank water heaters. Local building codes may require a permit and a larger Gas feed pipe.
Also if you're going to use the old Pressure Relief Valve DO NOT test the valve by activating the little lever. Once used over time their internal seals weld onto the closed seat and tend to rip and leak if you test the valves function. Replace with new ( $15) if it's been operated. Most plumbers now use Braded Feed Lines from/to the Water sources, making future replacements easier. You might find the replacement Tank is not the same geometry as the old one, having longer braided feed lines helps when they are on opposite ends of the tank top and the original feed lines are copper and wont reach the new tank pipes or the tank gas starter door is on the back side requiring you to rotate the tank 180. If you're changing size, measure the width and height. It might not fit the old installation.
Apr 24, 2014 | TitanNet TITANTANKLESS. COM PRESENTS THE...
I have a 650 delta thermostatic gas combination control on a Rheem hot water heater that won't turn to to the proper pilot or off position to relight it. We have looked everywhere for trouble shootin
Jennifer, the instructions posted by Rheems on the heater are wrong. You must first rotate the dial clockwise, use force (in our our case) to get the pilot to its position. The folks at Rheems are nuts not to check their instructions before printing them and plastering them on their hot water tanks. Disgraceful, period.
Mar 30, 2014 | Water Heaters
Lochinvar DVN051 Water heater, I checked voltage on transformer, fine, checked pressure seitch, fine, blower runs fine, gas is on and stat clicks when I rotate it and kicks the blower os, I checked th
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also: Scroll up on same page for Pressure Switch heading.
Lochivar is made by Bradford White I believe.
Same troubleshoot page has link to Bradford White service manuals, and service manuals posted by AO Smith, in case this product is through one of their subsidiaries.
Rheem does not make this product, good thing for you because Rheem doesn't post service manuals.
Sep 09, 2012 | Honeywell Water Heaters
Change thermostat and heat element and breaker still wont get hot
It sounds like you need to do complete troubleshoot.
Next link has step-by-step.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Buy cheap multimeter from home center.
When testing voltage, rotate dial to 240-250-277VAC
When testing continuity or elements, rotate dial to Ohms. Upside down horseshoe is ohms.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 21, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a Rheem Electric water heater Model#71-52DB. It has no power and not heating when it does have power.
You need to troubleshoot water heater and electric going to water heater.
Troubleshoot takes about 45 minutes.
Typical electric water heater tank is fully repairable by homeowner using generic parts from home center or hardware.
Links below walk you through the steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Buy $5 multimeter from Lowes or Home Depot or Ace:
Install battery in multimeter.
When testing voltage, rotate multimeter dial to 240 or 250 or 277 VAC.
When testing continuity or elements, rotate multimeter dial to ohms (upside down horseshoe symbol is ohms)
Image of Multimeter
Jan 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I had a bad lower element changed it then water heater wouldnt work at all so i changed the thermostat still nothing when i wire it up correctly but when i jump from one side to the other it works but i...
Take 30 minutes and do complete troubleshoot:
Buy multi-meter from home center.
When testing for voltage, rotate multi-meter dial to 240-250-277 VAC
When testing elements and continuity, rotate dial to to Ohms
Follow steps from top of page to bottom.
Page has photos of correct thermostat wiring to double check wiring.
If your wiring varies, connect wires as shown or add a comment.
Dec 30, 2010 | RELIANCE ELECTRIC WATER HEATER
Help! I can't get the water heater to go on! I KEEP TRYING to set the dial, but it's not working
If I understand correctly, you have the WH40 water heater timer.
If timer dial will not rotate, then use manual override to turn on circuit to water heater.
If manual override will not move back and forth, the tripper pin might be wedged against the lever.
Lift and rotate dial out of way.
If manual override does not click back-and-forth, then timer is probably bad.
If manual override clicks, but water heater does not turn on, then check electricity.
If you need more help, post a comment and I will respond
Oct 28, 2010 | Intermatic WH40 - Water Heater Time Switch...
My old randall 30/60 wont "rotate" probably knackered! can it be repaired or just replaced
The inners gears in these are plastic and slowly wear out. As usual throw away society, not worth reparing. 99% of timers are now digital, not too expansive for just a simple timer. If you do buy yourself go to somewhere where they will check the new one is compatible and has a changeover wiring diagram or instruction leaflet. If you are careful, turn of all power etc. might be able to do it yourself.
Sep 16, 2010 | Water Heaters
Clock on Intermatic WH40 Timer Switch does not rotate
Timers are a waste of time . I would disconnect it and get rid of it. Water heaters nowadays are so energy efficient and the thermostats take care of when it heats and shuts off. Your timer might save you pennies a year!
Feb 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
Bissell Pro Heat 2x Select Pet Upright Deep Cleaner Logo
32 people viewed this question
Top Bissell Water Heaters Experts
yobo007
yobo007
SirEbrum
ray gallant
Are you a Bissell Water Heater Expert? Answer questions, earn points and help others
