Question about Ovens
Igniter not lighting - Ovens
    Prodigy:
    An expert who has answered 500 questions.
  • Ovens Expert
  • 650 Answers
If it is a glow bar or hot surface igniter it is very likely that the igniter is bad. This is fairly common. You can check the igniter for continuity if it is open then it is the problem. If it has continuity it may still be the problem but there may be a problem with the oven thermostat or electronic control. This would be best referred to a qualified service tech
Posted on Nov 20, 2013
Oven wouldn't light so I replaced the igniter. It now lights fine at start up, but won't light when oven needs to reheat.
Certain igniters work together with the oven gas valve that senses current, once they get hot, may not function properly. Was the igniter lighting up at all before? Could also be the temp sensor.
Oct 27, 2013 | Whirlpool Ovens
Oven burner doesn't light. Igniter doesn't light. Boiler burner does light and Igniter does light
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Mar 01, 2010 | Maytag Ovens
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
The gas oven will not light. gas burners light but oven does not
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
O-defective thermostat
O-defective selector switch
O-defective gas safety valve
O-defective gas valve coils
Sep 20, 2009 | Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Frigidaire Gas Oven
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Jul 10, 2008 | Frigidaire FGB24L2A Gas Single Oven
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
Oven won't light
Jun 23, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
