Indesit WIL143S flashing lights
Just got a second hand Indesit WIL143S. The programme turns on and fills with water then door lock, stain removal, easy iron and extra rinse lights start flashing and nothing else happens. It does drain and spin seperately.
  • 5 more comments
  • Anonymous Feb 10, 2008
    i have tryed everything
    have the same problem and tryed everything any other suggestions as its brand new
  • Anonymous Mar 16, 2008
    I have tried turning it off at the plug for two minutes and it did not work any more suggestions
  • Anonymous Mar 13, 2014
    Programme not starting Door shut programme set nothing happens
  • Anonymous Mar 14, 2014
    on off door lock flashing
  • Anonymous Mar 20, 2014
    When i push the on button all the lights flash and nothing happens. you cant turn it off so have to turn off at plug. have to repeat a few times before it will work..??
  • Anonymous Mar 29, 2014
    Programme won't start, lock light flashing
Hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
Posted on Jan 20, 2008
  • 67 Answers
Sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Posted on Oct 08, 2007
SOURCE:
Indesit IWDE126 door lock red light flashing/beeping
The door lock is mechanically/electrically defective and should be replaced.
Oct 15, 2018 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
washing machine working until final drain, rinse and spin then 3 lights flashing, door lock, stain removal and extra spin.
Unable to empty machine or unlock door.
any suggestions
May 15, 2008 | Washing Machines
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Washing Machines Logo
1,682 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
