Question about Kenmore 500 6952 Dryer
How do i increase drying time coin operated kenmore model 110.60172001
    Sergeant:
    Champion:
  • 310 Answers
In the coin box adjuct the timer by a set screw
Posted on Nov 21, 2013
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
I've recently purchased a FirgidAir laundry dryer (Model FCED3000ES ELE). The company installed drying time is 45 min that doesn't dry load well. I want to extend drying time to 1hr. Could you...
If you are looking to increase the time, the dryer comes with additional wheels for the timer. The one with the least number of posts is the longest time. I forget if it has two or three posts. You just remove the timer from inside the coin box and slip off the 45 minute wheel, and slide on the 1 hour wheel, and then put the timer back. Very simplet.
Jun 14, 2011 | Frigidaire FCED3000ES Dryer
Washing machine wont come on but i check the plugs and the push button are okey . you know any other parts that needs to be replace ? thank you.
If this is a kenmore front loader (boxy type made by frigidaire), the button must be
depressed for several seconds. The second problem with this model is the "coin
mechanism" cam must be in the correct position to operate the machine. If someone
puts in coins two times without starting, it can get out of sequence with the timer.
If you have a key, open coin box and move the metal arm back until the cam advances
to just before the big dip. (with the unit unplugged). The next cycle will allow the
arm to drop and engage the microswitches. If you don't have a key put coins in the
slide mechanism as though you were going to start the machine and
depress button until machine starts, this will reset the cam to the correct position.
Hard to explain but if you look at the coin mechanism, it will become obvious.
If you need a new mechanism it is called the "start mechanism" for front loaders.
Hope this helps.
Apr 16, 2011 | Kenmore 3.1 cu. ft. Coin Operated Extra...
The duration on commercial kenmore coin operated dryer isn't long enough to dry the clothes. How do i lengthen the cycle time?
Some dryers require timer cams to extend the cycles. The electronic dryers are programmable. The owners manual will tell you how to change the times. The owners manual can be downloaded at www.searspartsdirect.com.
Kelly
Mar 21, 2011 | Dryers
Dryer is intermittently drying. Gas
Replace operating thermostat on back of dryer. It looks like a coin.
Apr 22, 2009 | Kenmore Dryers
Coin-op dryer: changing the length of the cycle
that is correct, there a re multiple "cams"/discs that will increase/decrease times, they should be inside the lock box atop the machine, they come with the unit when delivered and that s the likely storage spot for them
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
Change the price on Coin Operated Laundry
Contac Bob Pinkney at LoBright manufacturing company, Queens Village, NY
Feb 13, 2009 | Dryers
Coin operated washer and dryer
remove the coin slot out remove the slug used to plug the coin slot
Feb 24, 2008 | Washing Machines
Kenmore 500 6952 Dryer Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
