Question about Pacific Bearing Aztec Sidewinder Strip Brush, 10 inch
Removing the brushes from an aztec sidewinder
I have the Bernina Artista 180. It is not recognizing when I turn the bobbin winder on. Any suggestions?
For a quick fix and until you can get your machine serviced, pick up a Sidewinder bobbin winder (check to make sure your bobbins will work since the larger Bernina bobbins may not). I purchased a Sidewinder a few years ago and use it all the time. Saves wear-n-tear on the machine but also lets you quickly wind multiple bobbins without having to unthread your machine. Most Sidewinders are battery operated, but mine also has an AC adaptor for electrical usage too.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Sep 24, 2017 | Bernina Sewing Machines
Bobbin not not threading, what's the problem?
We don't know the make & model of your machine. Are you trying to wind the thread onto the bobbin?
FWIW, for ~$30 there is a stand-alone bobbin winder called "Sidewinder" that can be used to wind all your bobbins. It saves wear-n-tear on your machine and you can wind bobbins without removing the thread from your sewing machine. Just be sure to verify that your bobbins are compatible with the Sidewinder.
Available at JoAnn's, Walmart, Amazon...
Jul 19, 2017 | Sewing Machines
Bobbin winder not working
For ~$30, you can purchase a stand-alone bobbin winder (Sidewinder) that you can use to wind your bobbins. Saves wear-n-tear on your machine and you can wind bobbins without unthreading your machine. Just be sure to verify your bobbins are compatible with the Sidewinder.
Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Bobbin Winder
Jul 18, 2017 | Sewing Machines
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Jul 16, 2017 | Singer Sewing Machines
Drivers side airbag removal on pontiac aztec
go to your dealer airbags can be dangerous
Mar 26, 2015 | 2001 Pontiac Aztek
I need drivers for microsoft sidewinder force feedback pro joystick that works with windows 7 64bit
buy a joystick that will work with win7, because the MS Sidewinder has no driver, and MS has no vested interest in developing one...
Jan 18, 2010 | Microsoft SideWinder Force Feedback Pro...
Microsoft Sidewinder Force Feedback Pro 2 Drivers
You should be able to download them from the Microsoft web site.
Jun 15, 2009 | Microsoft SideWinder Force Feedback Pro...
Pacific Bearing Aztec Sidewinder Strip Brush, 10 inch Logo
Top Pacific Bearing Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Pacific Bearing Tool and Hardware - Other Expert? Answer questions, earn points and help others
