Question about Husqvarna Zero Turn Mower Z5426
Husqvarna Problems intermittent starting issues gas is fine... new mower but sometimes will not fire
    Scholar:
  • 61 Answers
When it won't start have you removed the spark plug after cranking it over like you were attempting to start it cold with the choke on and then inspecting the spark if it's wet then you know it is in fact getting fuel enough to start and you can proceed with the next test which is putting the spark plug back on the plug wire and grounding the spark plugs base against the motor so it can ground and crank the motor over like you again were trying to start it and seeing if your getting a good blue colored spark that is blinking fast and doesn't stop blinking/arching at the plugs electrode. ( shut the choke and throttle positions off and when you ground the spark plug do so away from the plug hole) This test is easier if you have someone turn the key for you so you can watch what the spark plug is doing while cranking it over for about 5 to 10 seconds. If erratic or no spark and assuming you've changed the spark plug or plugs then something is grounding the shut off side of the coil or coils or you have a coil problem.
Posted on Nov 27, 2013
SOURCE: Husqvarna Ride Lawn Mower does not want to start
I've discovered that if you leave key on battery will be drained to dead. Checking battery with meter shows +12v. When key is turned to start position nothing happens. When you connect meter to battery terminals and put key to start position the meter reads about .250 VDC. Even after taking battery to Advance Auto and have it checked it still does same thing. Eventually I jumped my mower with another battery that was being used in my scooter. Bingo! all worked well with jump. You would probably be able to jump with car battery with no problem.
Posted on Mar 26, 2009
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
  • 100 Answers
SOURCE: my husqvarna mower starts and
sounds like venting problem...check fuel tank cap for venting hole...
Posted on Aug 14, 2010
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
  • 640 Answers
SOURCE: My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Posted on Jul 11, 2011
Start no fire checked all fuses and seat switch everything seems fine will not start
www.husqvarna.com/asia/support/contact-husqvarna
Coudl be coil , power pack, timing mod.etc.
Jul 01, 2014 | Husqvarna Zero Turn Mower Z5426
Why my mower sputters while idiling and at times
If the gas is more than 30 days old, and it has been sitting in hot weather (90+), then it starts to go bad, rather quickly.
(And if no fuel stabile was added to the fuel before hand)
Or, if the gas can spout was not sealed properly in storage, it could have been water contaminated, from sprinklers or rain.
It may not necessarily be the motor itself.
The cheapest fix, is to drain all of the water out of the mower's gas tank. (you will still have some bad gas in the lines)
Put some fresh gas, with fuel stabile, in the tank and see if it will start. If it does, it may take a few minutes of operation to flush the bad gas out of the line, and motor.
That was the problem with my mower. It turned out to be a gas issue, and my mower was fine. Good luck.
Oct 16, 2013 | Husqvarna Zero Turn Mower Z5426
The fuel tank breather is in the fuel filler cap, run the machine with the filler cap loose to allow air in, if the tractor runs ok, then replace with a new cap.
Jul 17, 2013 | Garden
Spitting gas out of carb with new carb and plugs
could be the coil getting hot and loosing spark
Feb 22, 2013 | Garden
Husqvarna RX4222F The engine just dies out of the blue. Sometimes after 2 hrs of mowing, sometimes 10 minutes. Cant isolate the problem. It cranks and cranks but does not fire. Eventually, it cranks...
Hi, they have had issues with the fuel shut off solenoids in the bottom of the carby not holding open which intermittantly starves the carb of gas. This would be the first thing I would have replaced, especially if the plug is dry but you still have spark when it stalls out. Regards Phil.
Jul 18, 2012 | Husqvarna RZ4222F 42" 22HP Zero Turn 2011...
Carburetor problems husqvarna 18hp kawaski FH531V walk behind mower 52"
drop the bowl off the bottom and see if the float is stuck or the needle valve might be stuck as well
Apr 09, 2012 | Garden
After running husquavarna riding mower 23hp mower starts backfiring and ends up quitting. mower will start back up but die out again as descibed.
I had the same issue and after trying everything I tokk the gas cap off and noticed there was negative pressure in the fuel tank when I broke the seal... I'm pretty sure the gas cap was just too tight, I threaded it back on but did not torque it down and the mower is running fine.
May 13, 2011 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Jul 29, 2010 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Problem keeping engine running on Husqvarna 22HP VT riding mower
Take the fuel bowl off and clean it real good as well clean the fuel jet. It may be the bolt that holds the fuel bowl on. I am not sure. I use my air compressor to blow it out also get a real fine wire and put through the fine hole may help. It does not take very much dirt to make an engine not run right. I repair a lot that way that is not running properly.
Jun 06, 2017 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
1997 chevy Cav, Intermittent starting issues
Might be something in your gas tank that gets stuck, I've heard of people putting whiffle balls in peoples gas tanks and that happens.
Mar 18, 2009 | 1997 Chevrolet Cavalier
Husqvarna Zero Turn Mower Z5426 Logo
144 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
