Question about Sub-Zero 685/S Stainless Steel Side by Side Refrigerator
Subzero condensor fan direction
Replaced a bad Condenser Fan and now the ref and freezer are warm. Ice has formed on the interior condenser and frost on back wall now in front of wall plate. Ice is on the upper left quadrant of the interior condenser. Probably a leak and a thousand dollar repair but I want to check air flow direction on my fan first. Mine is set to pull air over compressors and through the condenser. Is this correct?
  • Sub-Zero Master
  • 2,341 Answers
Yes the air blows to the compressors,was the freezer and fridge running before you changed out the condenser fan motor?it sounds like you do have a freon leak in the refrigerator side but on a sub zero you have a compressor for the fridge and another compressor for the freezer so whatever is happening in the fridge side has nothing to do with the freezer,you might have a bad freezer compressor now from having a bad condenser fan motor,if the compreesor was running hot from the fan motor not working you could have cooked the compressor on the freezer side,let me know what's happening with it.
Posted on Nov 21, 2013
  • 4 more comments
  • Sal DeAngelo Nov 21, 2013
    yes the air blows to the compressors,was the freezer and fridge running before you changed out the condenser fan motor?it sounds like you do have a freon leak in the refrigerator side but on a sub zero you have a compressor for the fridge and another compressor for the freezer so whatever is happening in the fridge side has nothing to do with the freezer,you might have a bad freezer compressor now from having a bad condenser fan motor,if the compreesor was running hot from the fan motor not working you could have cooked the compressor on the freezer side,let me know what's happening with it.
    yes the air blows to the compressors,was the freezer and fridge running before you changed out the condenser fan motor?it sounds like you do have a freon leak in the refrigerator side but on a sub zero you have a compressor for the fridge and another compressor for the freezer so whatever is happening in the fridge side has nothing to do with the freezer,you might have a bad freezer compressor now from having a bad condenser fan motor,if the compreesor was running hot from the fan motor not working you could have cooked the compressor on the freezer side,let me know what's happening with it.if you removed the back wall of the fridge side and ice is where the lines meet the evaporator coil you have a freon leak,if it's under 12 years old the coil is covered under warranty and you will pay 550 to 650 dollars for the repair,if over 12 years it could cost 10 to 12 hundred for the job,if the freezer compressor is bad that could cost 17 to 2000.
    sorry about that,every time i tried to send you this email it said it couldn't be sent because to many people were signed on the site
Clear the air way for circulation
Posted on Nov 20, 2013
guly
  • 67 Answers
SOURCE: SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Posted on Sep 24, 2007
JJDown75
  • 8 Answers
SOURCE: Hi...need help...subzero 550
Make sure the condensor is clean, blow some Air though the Condensor to make sure good Air flow towards Compressors. also, you might have a bad defrost timer or Freezer Control... worst case you might have a bad Compressor... hope I can help....
Posted on Apr 15, 2008
  • 56 Answers
SOURCE: Subzero 561 Fridge side works, Freezer side working fine
Sounds like a cold control. It is located behind the panel and can be ohmed out to check for proper operation. You need to remove the light shield then after the shelves have been taken out remove the two screws that hold the fan shroud in place. This will allow back panel to come for so you can check the cold control. It should read as a short in all positions except off when the cap tubes have come to ambient temp. If you get the back off and see ice on only a small portion of the evaporator you have a sealed system problem and need a qualified technician.
Posted on Dec 05, 2008
woodchuck789
  • 4070 Answers
SOURCE: Subzero 590: small upper fan inside the refrigerator not working
The fan circulates the cold air accross the evaporator to distribute the cold air around the fridge. It appears that your defrost system isn't working since you have ice buildup. You have a defrost heater and defrost thermostat and timer or motherboard which need to be checked to determine the problem. How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 31, 2009
SOURCE: My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Posted on Nov 21, 2009
Top freezer cant freeze the fish and not cool
Make sure your 'Freezer Fan is working ... if not replace it. Then, you may have a 'Defrost Problem' .. check freezer rear wall for any ice build-up. If there is ice .. the ref will have to be shut down ... remove all freezer food and remove freezer rear wall (panel with freezer fan) de-ice evaporator coil with hair dryer. Check Defrost Heater for resistance value (approximately 20 ohms ... means it OK). Replace the Defrost Terminator ... (if Open on ohms check) ...recommend replacement as this part is very troublesome and is very inexpensive to buy. Make sure, Condenser Fan under ref is working ... if not replace it. Make sure Condenser Coil under refrigerator is clean of dust and dirt. If needed vacuum coil. Finally your Defrost Control assembly may be at fault and will need to be replaced. Good Luck! Handy Henry
Feb 18, 2017 | Refrigerators
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Fridge warm. Freezer frosting over. I've
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer ( evaporator) fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
There can be many factors for the no cooling factor: the condenser coils could be blocked with dust, the condenser fan could be bad or stuck, the freezer fan could be stuck or bed, the freezer coils could be blocked with frost because the self-defrost system is not working or the compressor is not running because of a bad relay etc.
Please check this link to get a detailed idea about your issue:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 07, 2011 | Jenn-Air Jenn Air Side-By-Side...
Freezer not cold enough to freeze food and ice maker not making ice
Hi first thing you want to check is if the freezer is frosted up in the back, also the center mullion/separator between the refrigerator and the freezer and see if it is warm to the touch. If it has frost you are looking at a defrost problem, if its warm in the middle your looking at dirty condenser or bad condenser fan motor. If neither of these are present check to see if fan is running in the frreezer, and if its and none of these other symptoms are presenst you could have a freon leak or sealed system issue.
Sean
Mar 26, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Subzero bottom freezer dont freez well and dial is to the maximum
Possible problems:
frost build up on the back panel.
freezer fan not working
compressor low on freon
defrost not working
dirty condenser
condenser fan not running
try to see if you can figure which one (or not)
then let me know
Mar 29, 2010 | Freezers
Refrigerator warm, freezer fine, condensor fan not working.
yes and it is the evaporator fan inside the freezer, and condenser fan near compressor
Mar 25, 2010 | Refrigerators
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
It stopped freezing and the temperature keeps rising
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
How to check stuff>
Dec 13, 2009 | GE Profile Arctica Stainless Steel Top...
I have a Frigidaire side-by-side refrigerator model FRS26ZNHB1. The blower is running continuously and the temperature in the freezer is not as cold as it should be. (Ice cream is soft - things are...
bad door seals, frosted up coils, low refrigerant, dirty/clogged condenser coils (under fridge), bad condenser fan. check the fan in the back. clean out the coils with a vacuum under the fridge. see if there is frost on the back wall of the freezer. if there is, you'll have to remove the back wall and defrost the coils with a hair dryer. check the door seals for leaks. replace if necessary. if all is well and still warm, you have a freon leak. call in the pros.
Nov 13, 2009 | Refrigerators
Not cooling, fan making noise and now humming
Oct 27, 2009 | Admiral Refrigerators
Sub-Zero 685/S Stainless Steel Side by Side Refrigerator Logo
189 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
