How to get in to Dlink2100ap router
I want to make factury setings
    Problem Solver:
  • 6 Answers
I have found that it's common to have to hold down the reset button for 30 seconds, then with the reset button still depressed, unplug it for 10 to 30 seconds and plug it back in without letting honor the reset. Give it a 30 count after powering on before letting go of the reset. Works nearly every time.
Posted on Nov 20, 2013
Resor factury shdls router ct524(hardwair)??????No reset button on the back of the modem!!!!!!!!!!!!
The factory reset is completed via the configuration page. Enter the IP address of the router in your browser and then login. For
example, if the IP address is 192.168.1.1, enter http:// 192.168.1.1 Look for Erase and Reboot and click to reset to factory defaults. Caution! If you reset your device to the factory default, any changes to
parameters will be lost and all parameters will revert to their default values.
Try root at the default username and password unless it was changed. (or root and 12345). I am not aware of a hardware factory reset i.e. pin hole.
Dec 17, 2014 | Computers & Internet
How do I reset my Dlink to factury settings
Press RESET button for 10 seconds it is in the back side of router. then all settings goes to defaults. connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then configure it. Let me know if you need further assistance. Thanks for using FixYa.
Sep 27, 2011 | D-Link DIR-615 Wireless-N Router (54682G)
When i give the passport given by d_link .my network does not accept that.i have just instalted a wierless rotate d_link dir 615.but anytime i enter the code it doesnot accept it.thankyou
if is a WPS setting for wireless, is beter to connect whit the small patch cord to the router and desactivate the WPS setings and go to wireless seting/security and put wpa/psk2 shared key, is more simply and easy to remember.
best regards
Sep 22, 2011 | D-Link Computers & Internet
Getting limited or no internet connectivity. reset ip stack and winsock, still no dice
there is something wrong with the lan or tcpip settings.set a menual tcpip v4 ip from the property of connection then open the router setting page.there will be tcpip setting or lan setting "all routers have diferent interfaces for seting " or find dhcp somware.set dhcp as server mode and rang from 192.168.1.2------------------>192.168.1.64.all router have not same ip seting in some router 192.168.0.2------------------->192.168.0.64.when you set dhcp sever mode these seting will automatically done.but if you want to increase your limit then use given example.
tell me your router model so i can tell you step by step procedure
Jul 11, 2011 | Computers & Internet
Wireless side of 4port linksys router not working hard wired switch ports working unable to ping router using dhcp if i configure a static ip on my pc i can then ping 192.168.1.1
try a factury reset on the switch by holding the reset button and pluging in the power at the same time and holding for 5 seconds- reconfigure router as required.
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
Hooked up arris modem with lynksys G series router
You have to set seting from routers menu. To use it hold 15 second router restart button, that restore factory setings, then go browser http://192.168.1.1/ , and use username "admin" and password "admin" in default. There you can set setting by your connection.
Aug 12, 2009 | Arris Touchstone 450a (CM450) Modem
Have high speed internet, but don't have a modem, just a cable to my tower, I connect that cable to my router, and the cable the router came with I connect to my tower and won't get internet to my computer...
Aug 12, 2009 | Linksys Wireless-G Broadband Router
I want to set factury default to my fair wall dlink dfl 210
With the unit on, locate the small reset switch on the back of the router. Insert the end of a paperclip into the reset switch and hold for 10 seconds. The router will restart itself and the WLAN light will stop blinking.  The router is now reset to factory defaults.
Remember The factory defaults username is admin, and there is no password.
Feb 09, 2009 | D-Link Netdefend DFL-210 (DFL210)...
Wanting to connect 2nd computer to internet, have router
If it is by wirless you will need to adjust the wirless adapter setings by going to your network conecsions click on the wirless conecsion and confiqir it to use stronger setings it should have a descripsion for all stings. I hope this will help you. Also do not forget to vote.
Jan 17, 2009 | Gateway Cable/DSL Router - 4Port [ Belkin...
When trying to use my wireless router it keeps disconnecting and re connecting itself. had to revert back to old wired router at mo, fustrating because wanted the freedom of wireless laptop useage.
It may be the seting on that laptop for the wirless adapter might not be set to the highest setings that you need to get a better conecsion. If you think this will help you i will post a comit with diresions to do this proseduer.
Jan 02, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
