Rca p61960 model has sound but no picture
The picture has went out but it still has the sound when turned on. I have had it unplugged for a few months and decided to try it again and still no sound the projection bulbs light up with a faint little glow
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
Control board and lamp may need replacing. Start with the lamp and then have a pro check the board if necessary. Good Luck
Posted on Nov 21, 2013
techman
  • 3130 Answers
SOURCE: Please Help!
A chirping sound from a TV set is the switch mode power supply trying to start up, but gets shut down because of a major short inside the set or in one of the circuits.. Most likly in this set, the horizontal output transistor is shorted because of a defective flyback transformer. Thats whats the common problem is with this set. A repair like this, if this is the only parts that are bad, will run you about 300 to 400 bucks or so. In some cases, not many but a few times, I have seen poor solder connections on L401 cause the horizontal output transistor to go bad. There are no user replacable parts inside this set, so please play it safe and seek out a pro to assist you in this repair. Good luck PS Please do not forget to rate this thread.
Posted on Dec 11, 2006
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
Posted on Jan 25, 2008
  • 5 Answers
SOURCE: RCA P61960 61 in not working
I am looking for parts for this television if you can't find a way to fix it, let me know
Posted on Mar 12, 2008
ensapp
  • 30 Answers
SOURCE: RCA P61960 projection screen. no picture, no sound. tries but shuts off.
It will depend on the Chassis number you have but it sounds like a bad Deflection module or a bad Convergence power supply module. The Convergence Power supply module is on the left looking from the back mounted above the deflection module. On newer models the picture tubes can short and put these sets into shut down mode ( Three Trys). Start by unplugging the CRT modules off the neck of the tubes one at a time. If it doesn't come on you have eliminated the tubes. There will be a Red and Black set of wires from the deflection module to the convergence power supply module. Unplug it. If it fires up then it's the convergence power supply module. If not it will probably be the deflection module. The flayback transformer is a common problem along with several bad caps towards the front of the board. Let me know if this fixes it.
Posted on Oct 14, 2008
Picture not on
no tv picture so
und comes on and goes off
Oct 23, 2013 | RCA P61960 61" Rear Projection Television
My rca 60" projection tv turns on and has sound
I had a 56 toshiba do that and it was the light bulb inside. It wasn't difficult to replace.
Nov 14, 2010 | RCA P61960 61" Rear Projection Television
Attention, SD TECH I read your 8/25/10 post on
This model does not use STK CHIPS. Look on back of set where model number is---what is PTK number---ie: PTK 169, OR PTK 195
Sep 01, 2010 | RCA P61960 61" Rear Projection Television
When plugged in, it makes a chirping sound.
hello it sound like 1 of the capacitors may blown or swelled up. with the power of you need to do a visual check of the board inside check for any burn't part i'e resistor capacitors transitors diodes any more info you need get back to me
regards
shaun
Mar 13, 2010 | RCA P61960 61" Rear Projection Television
I hear sound,but no picture. I was watching it heard a popping noise and the picture went out.
you will have to trouble shoot the deflection circuit it may be a bad flyback transformer and output transistor
most likley still worth fixing
Nov 09, 2009 | RCA P61960 61" Rear Projection Television
Oct 02, 2008 | RCA P61960 61" Rear Projection Television
HELP MY TELEVISION HAS NO POWER!!!!!!
have you checked the fuse inside the powersupply ? Where the power cord enter into the Power Supply.Or look for a red or black button that says reset.
Jul 30, 2008 | RCA P61960 61" Rear Projection Television
Rca model p61960 projection tv dead
More likely a bad flyback transformer......T.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
Feb 19, 2008 | RCA P61960 61" Rear Projection Television
Rca p61950 turn on and off by itself??????
Sounds like the front panel buttons are locking up the micro,unplug the unit and remove the back cover,just below were you removed the top screws you can look and see the top of the picture tubes,in fron of the middle tube is a small board,unplug the top left cable and this should restore the unit till you get the set serviced,this will not harm the set,the front buttons just wont work
Dec 01, 2007 | RCA P61960 61" Rear Projection Television
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
