Question about Air Tools & Compressors
Hittachi ec12 buzzing noise - Air Tools & Compressors
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Possible bad capacitor or motor but need more info
Posted on Dec 30, 2013
The e t c is buzzing what is causing this
ANSWERS: Oil Loss, Buzzing Noise, ETC. - Nissan Forum ' Nissan Forums
forums.nicoclub.com/answers-oil-loss-buzzing-noise-etc-t323273.html
Mar 20, 2008 - 3) Yet another buzzing, rattling or whinning noise. If you own a Quest van, Maxima, Altima 3.5 and some Z/G/FX vehicles, and get a loud ... Mysterious no-spark situation with a buzzing transmission
Mar 31, 2013
ABS brake fault light on, buzzing sound
Feb 7, 2011
ECU making loud buzzing noise
Oct 6, 2009
Buzzing noise under the hood towards the back of the engine ...
May 8, 2008
More results from forums.nicoclub.com
Buzzing noise at 2000-3000 RPM - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan-altima.../128490-buzzing-noise-2000-300...
Oct 28, 2003 - 6 posts - ‎3 authors
The "buzzing noise"; I can tell that I am not alone in having this problem but has someone figured out ... I fit does, that eliminates the brake rotors, tires, wheelbearings, CV's etc. ... BUT with an Altima it is probable the pre-cats. Loud humming noise when driving
Aug 29, 2009
Noise when accelerating
Jul 21, 2009
engine noise/whine - 05 3.5SE
Nov 17, 2006
My altima has a humming noise under my hood
Jan 17, 2005
More results from www.nissanclub.com
Jan 05, 2016 | 2000 Nissan Altima
Hitachi EC 12 2hp Air Compressor. Just get a buzz sound when plugged directly into 120v wall outlet. Piston and shaft turn freely. Have installed a new pressure switch. Just turned the compressor on...
Hitachi EC12 Air Compressor Parts : MASTERTOOLREPAIR.COM
Here is a site that says:
1. Are the capacitors good? (They get the motor going).
2. If they are, replace the stator, ($245)
If you don't find a good solution there, I would try taking it to a local motor rebuilder.
Gary
Dec 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I started my air compressor for the first time without any oil. Now it makes a buzzing noise. Is there a "simple" solution other than replacing the motor?
Running compressor without out oil generally will damage rod and deposit metal on crank lobe. Metal can be removed using 400 grit sandpaper cut into one inch strips pulling back and fourth untill lobe is clean as new. You will only need to buy the rod(about $20) and one sheet paper. Remove pump/motor from frame, remove two bolts holding cylinder to body and airline and pull up on cylinder to expose piston/rod. Usually the rod will slightly coat the crank with metal and seize. Remove or work rod off lobe. Clean crank area and add fresh oil. Parts available at www.toolpartsdirect.com Good luck
Sep 25, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My Hitachi EC12 builds pressure, shuts off, then air escapes
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However, I do want to replace it before the warm weather come to the north. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit and when using an extention cord I have a 10 guage cord that will carry the load needed to run the EC12. I have also changed to 100% synthetic oil.
May 15, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC12 plug it in and nothing happens. No noises....nothing. There is oil in the compressor and pump is moving freely.
Sure the outlet you plugged into is working, do not use an extension cord.
If there is power, then there is a black box, where the cord enters the unit., in here is the pressure switch, it tells the unit to work,
unplug the unit open it and see if the plate with the spring moves freely
and then try it again, if not you probably need a new one, I would contact
the company and see if there are problems with the unit and see what they will do for repair, or they might have a better option for troubleshooting this unit.
Feb 12, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Lost my ec12 manual in a flood out need to replace it
can get manual from where you purchased the unit if purchased new http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/hitachi/EC12
here you will find a parts manual
Jul 10, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hatachi EC12 Portable Compressor When I start the
well make sure air pressure is not too high. if not just replace it any air supply house carries them
Jul 02, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Air Tools & Compressors Logo
19 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
