Question about Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065
On/off switch buffalo bench grinder
Need a on/off switch for buffalo bench grinder bgbr 6cb
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
The switch is probably generic.. go to a Lighting store and see if they have equivalent
Posted on Dec 15, 2013
I need an on/switch for a 6inch buffalo grinder model #b-6cb cycle 60 1/2 hp voltage 110 amb2 3450 rpm serial#8587745
Find a Single Pole Single Throw (spst) toggle switch at the local hardware store rated for the load of the grinder. Wire the switch in place and viola you are done! Machines are stupid;they can tell the difference between an oem part and a replacement.
Aug 30, 2011 | Grinders
Starting coil switch I had to replace a bearing on my buffalo bench grinder and I cant figure out to put the starting coil switch back on or how it works
A coil is just that a coil and unless it has diodes it doesnt matter how you put it on. let me know (diodes are those things that are usually black with a silver stripe -cylindrical in shape)
Jun 23, 2011 | BUFFALO Grinders
I have a Buffalo B-10CB(CH) bench grinder and the on/off switch has broken, it's a push/pull type. What can I replace it with to make it work safely?
You could connect the wires of the switch together inside and bypass the switch. Then I would connect in the power cable a switch rated for 1 hp. You can use surface mount electrical box, with two cable connectors (one for the cable going into the grinder, the other for the cable going to the male cord end of the cable. Install a 120 volt switch inside the box (similar to the light switch in the wall). Make sure that the switch is rated for 1 hp. I would install the switch under the bench, under the grinder.
Joe
Feb 28, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
I have an B-6CB(KS) 6" buffalo grinder, the switch
The neutral line should never be switched--only the hot wire (black). If there are only two wires that went to the switch, you should be able to tie them together and the motor will run when plugged in. The switch should be a common SPST type either toggle or rocker to fit. Hope this helps!
Dec 26, 2010 | BUFFALO 10" Bench Grinder
17202 8'' bench grinder 3yrs old hasent run 1 hr needs on off switch wilton stated after 6mos of waiting for soposed back order that co that maid these for wilton is out of business they said try lowe;s...
go to your local marina and buy a simple on off switch or take the wires off the switch on your grinder and hook them up to a extension cord and put an inline light switch on the cord.
Oct 21, 2010 | Wilton 17202 8" Bench Grinder
Need an on/off switch for a buffalo bench grinder model B-6CB 1/2 hp. 41/2 amp. serial #775713
I had the same problem with a Northern Tools bench grinder. These are made in China and parts are hard to come by. I had enough room after removing the old broken on/off switch to install a single pole 15 amp light switch like you use in your home. I simply installed it horizontally and then put the switch cover on. It works perfectly. If you do not have enough room then look for any 15 amp or larger switch that will fit in the housing. Any on/off switch will work. You could even mount the switch on the bench in a switch housing and run the wires from the grinder to the switch and back if need be. Just be safe and make sure there are no exposed wires. As a last resort you could remove the switch connect the wires, eliminating the switch and use a plug in wall switch such as this. 4147a14.png
Apr 23, 2010 | BUFFALO 10" Bench Grinder
I retrieved a Buffalo bench grinder, Model B-6, from where it had been stored for at least 11 years. Prior to that, I don't know its history. I plugged it in, and it runs. Here is my question: Do these...
A bench grinder would be unlikely to need oiling, but if it has such a provision there would be spring loaded caps or a set screw caps on the motor body near both arbors. The real concern is if the wheels have been compromised by taking a hard bump that could weaken them. This is an unlikely problem if grinder hasn't been dropped or had something heavy drop onto a wheel. If you have no reason to suspect wheel damage, and it runs without squeaking or excessive vibration, and the cord is not damaged, and there are no loose parts on it - then you have nothing to worry about. But you might want to consider "dressing" the wheels. Google "Grinding dresser" and read the Wikipedia article.
Apr 13, 2010 | Grinders
Model 397.19471 need switch but can not find. please help? 8 inch bench grinder
Call the Sears Craftsman help line they will have the parts you need
Apr 02, 2010 | Craftsman 10" Bench Grinder
NEED ON/OFF SWITCH FOR BUFFALO BENCH GRINDER MODELB-6CB-1/2 HP 6 '' 110 VOLT
You can get a replacement toggle switch at any hardware store look in the electrical department.
Jun 10, 2009 | Grinders
Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065 Logo
66 people viewed this question
Top Buffalo Tools Electrical Supplies Experts
Bill Boyd
Lawrence Oravetz
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
