Question about Diehl 24hr 120v Timer Clock Spst 801014 Ta4071
Replacement for Diehl type 880 T85
What is the lowest cost to purchase this timer on the internet and are there any substitutes for this timer available
  • Diehl Master
  • 15,950 Answers
3 Suggested Answers
SOURCE: A me occorrerebbe un timer
La tua domanda non ha senso.
http://www.spasandmore.net/index.php?l=product_detail&p=454
Posted on Jun 30, 2011
riceski
  • 1851 Answers
SOURCE: We are STC Vietnam_
What size STD are you looking for - there are many different ones.
Posted on Jul 11, 2011
I have a Frigidaire FRS26R4CWE both the Freezer 30 degrees and Refigerator 41 degreeswere not cold enough. This a spare basement refrigerator that we use once in while. There was no ice in the bin. Ho
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are going to have to remove the back cover in your freezer. You need to inspect what is going on.
1.) Evaporator (Cooling coil) motor - If the fan motor has failed you will not get air flow through the cooling coils.
Substitution: 5303918549 Cost: $60.00
You have a old unit. This is a substitute motor. You will have to cut and splice wires to install. If you have a multi-meter, if you get 110 volts across the motor and it is not running, then the motor is bad.
A service call for this would be about $400.00.
2.) Cooling coil Iced up - If the coil is iced up you are not going to get air flow through the coil. Your defrost heater may be bad.
25438946-rodi0hq003gjvlyl45o52cgv-2-2.jpg Substitution: 5303918255 Cost: $80.00
If you have a multi-meter, set it to the lowest Ohms. If you get a reading of OL or something under 25 Ohms, then the heater is bad.
A service call for this would be around $450.00.
3.) You may have a bad thermostat - This component is mounted on the upper right had corner of your cooling coil. They explode where the back pops out. This component needs to be spliced and wired.
Part #: 5303918214 Cost: $15.00
A service call for this would be about $350.00.
4.) If all of the other components check out, then you have a bad defrost timer. It is located in your fresh food section upper left under the housing cover.
Substitution: 5303918476 Cost: $82.00
A service call would be about $500.00.
Look, you have a older unit that has substitution parts. If you are not handy do not attempt the repair.
You may wish to consider going to a Sears Factory Outlet (Scratch & Dent) Store. You can save $300.00-$450.00 on a unit, and get a one year warrantee with it.
Rule of Thumb: "If the repair cost is 1/3 or more than the original purchase price, then buy new".
Feb 16, 2015 | Frigidaire Refrigerators
ONE DOUBLE BURNER ONLY WORKS ON HIGH NO MATTER WHERE I SET IT
Hello Miguel;
My name is Peter. I am a retired field service appliance technician.
There are two electrical components that will cause this problem. The most probable cause is the burner element. Each of your burner elements have a independent temperature sensor. The sensor controls the burner element temperature.
Substitution Part Number: 4453909 Cost: $85.00
This surface element (part number 4453909) is for electric ranges, including Whirlpool electric range model GJC3034RB00.
Unplug the range or shut off the house circuit breakers to disconnect electrical power to the range before replacing the surface element. Wear gloves to protect your hands when replacing surface element on your electric range.
This is a manufacturer substitution. Part may differ in appearance but is a functional equivalent to priorparts including 9759351.
OR:
PART NUMBER: 8523698 Cost: $71.00
The other less likely electrical component is Surface Element Control Switch. Each burner has a independent control switch.
Cost: $46.00
To check the switch: Remove the switch 2 contacts on the left. With a multi-meter, set the meter to the lowest Ohms (Omega Symbol). Put one meter lead on one switch contact and the other meter lead on the other contact. If the switch is good you meter will read "0" Ohms.
Jan 18, 2015 | Whirlpool GR673LXSS - Stainless Steel...
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
How to program an OLDER utilitec indoor digital 2-outlet timer
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#49566
2) Clear description of buttons was key for finding same/similar timer.
This timer is sometimes substituted for Utilitec 155671, and is discontinued design from Woods, which could have been another brand name prior, but does not appear on internet otherwise.
3) Same timer design may be released again sometime. Expect the Chinese to grab anything not nailed down and flood market with 'new' line of cheapo timers with bogus 1 year warranty direct from no-email-smog-air-manufacturing LTD.
Feb 24, 2013 | Hardware & Accessories
LE6090XS Dryer timer open
Timer part # is 696434. But, as you already know, it is no longer available. You might try doing a ebay search for that timer.
Sep 01, 2017 | Dryers
Need a hp light engine where could i purchase one
Sadly, there is no substitute. I was just quoted about $1500 for one (from HP), if I were to try to buy it (through a repair shop), and there are basically no parts available anymore for these TVs (everything is pretty much being recycled/refurbished, but availability is quite low).
Mar 27, 2010 | HP Pavilion MD5020N 50" DLP HDTV
Replacement substitute for Fender Sunn power transformer 28-4150
I can't find a schematic that references the transformer and cannot find a replacement either. I'd contact Fender for a reccomended substitute.
Jun 22, 2009 | Music
Time Saving Question
A timer on a conventional electric water heater can save 5-12% on your hot water bill. The water in the tank remains hot for up to eight hours or more while the water heater is not in operation, depending on the insulation and age of the unit. However, the hot water is still available for household use until it is completely consumed. Thus, if a household has a fifty-gallon water heater, it will have fifty-gallons of hot water available while the water heater is not in operation. Most households won't notice the interruption unless they have high hot water use patterns in relation to tank size. It is best to set the timer during hours when hot water use is lowest, typically during the work day or at night. Adjusting the timer may be necessary if households experience a shortage of hot water.
Aug 27, 2008 | Intermatic EI210 Electronic Auto Shutoff...
Diehl 24hr 120v Timer Clock Spst 801014 Ta4071 Logo
560 people viewed this question
Top Diehl Hardware & Accessories Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Gene Haynes
Are you a Diehl Hardware and Accessory Expert? Answer questions, earn points and help others
