Question about Brookstone Softtouch Acuvibe Body Massager
My model #D3-15A does not work. What do I do?
Just stopped working. At first, it was very little vibration and now nothing
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Vibration cellular
there should be a vibration button at the lower keys hold it in
Dec 02, 2013 | Samsung Omnia Pro B7320 Smartphone
How do I make my EnV3 stop vibrating?
Take out the battery and put the phone in some rice. It should help completely dry your phone out.
Dec 04, 2011 | LG enV3 VX9200 Cell Phone
My vibrate will not stop vibrating. I"ve tried
Hi, well i guess you have tried setting the settings and turned it off? if not then well do that, however IF it is not that and you cannot stop it, try a factory reset, then you will have to set the phone up all again but if it works it is a small price to pay? In any event if it will NOT stop vibrating, then you have a microprocessor fault, and the phone will have to be repaired or replaced? If so you need to take it into an LG phone repairer and ask for a "Quote" as to what it may cost, and go from there.
Oct 15, 2011 | LG TracFone 600 Cell Phone - TF600GP4
I have Nokia 5530 XM for a year and a half and a year ago my USb stopped working, when i connect it nothing happens... also today vibrations stopped working out of nowhere... is this a software problem?...
hi! eminem,
the problem you are facing the problem is not only a software its also because of hardware because the reason is nothing but the vibration stopped working.
you are requested immediately visit the Nokia authorised service station for the repairing of the handset.
Regards,
Prakash
May 08, 2011 | Cell Phones
Phone wont vibrate
ok i dont know if this solves the problem for good, but i do know that it solves temperately. I went to phone settings and set the ring tone profile to vibrate. then i kept pressing the play button until the squeaking went away. It seems as though once the little moter in the phone goes at a constant speed it stops squeeking. the squeaking stops for a good while and is better than nothing. Someone tell me if this works for them. thanks ;]
Apr 17, 2009 | T-Mobile Wing™ Smartphone
Install subs on back doors on a 95 suburban
Install Dynamat. That should stop the rattling and distortion. the distortion is from the door vibrating the sound waves and messing the sound molecules up before they reach your ears. stopping the vibration should stop the distortion.
Jan 20, 2009 | Insignia 600W Bridgeable Amplifier with...
Idling Vibration-Intermittent
Hi, that vibration is when the cooling fan comes on ,is comon in many diferent cars, enjoy your volvo,they are grate cars..........
Nov 06, 2008 | 2003 Volvo S60
Vibration in Steering Column at Idle
Engine vibration is the cause of this issue, it is the biggest complaint from many owners, changing the engine mounts will help, as mounts age the rubber gets hard and they don't absorb vibration like they should, new mounts help issue, but it will no stop it altogether. A faulty MAF will not cause vibration, just a hesitation on acceleration at times
Oct 03, 2008 | 1993 Saturn SL2
Samsung SGH-p207 Vibrating All the time
if you vibrating continuously, it probably needs service, but if you mean it just won't ring instead of vibrating when a call comes in, go to settings in the main menu (usually the "ok" button), then sound settings
Oct 25, 2007 | Samsung SGH-p207
Brookstone Softtouch Acuvibe Body Massager Logo
Top Brookstone Health & Beauty Experts
Da Doc
Tom Chichester
Are you a Brookstone Health and Beauty Expert? Answer questions, earn points and help others
