Question about LG DLG6952 Gas Dryer
Kenmore dryer model #71523210
How to, get to gas valve to conevert
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Kenmore gas dryer no heat.
the automatic ignitor is bad and needs a replacement
Feb 05, 2010 | Kenmore 73952 Gas Dryer
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
Gas dryer starts to tumble but it doesn't get hot and dry clothes
It's either a ignitor or the gas valve. Is this something that you could work on?
Sep 02, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer model 75291. The gas dodes not start
first, check to make sure gas present to unit, and power to the ignitor. if no power, replace timer, if power, check the ignitor for continuity, if open, replace. If ok, check to make sure none of the thermostats are open, if they are, replace. If ok, check gas valve solonoids, they should not appear melted or stuck, if so replace. If still no function, replace gas valve.
Jun 30, 2009 | Dryers
Will not heat
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ... All these will cause this problem.
Mar 22, 2009 | Kenmore 74672 Gas Dryer
Kenmore Model 110.76912691 gas dryer that heats intermitently
Replace the solenoids on the gas valve. These are often intermittent befor total failure. Hope this helps!
Feb 26, 2009 | Kenmore 63942 Dryer
Kenmore 72602100 gas dryer runs but no heat
gas dryers would have an igniter to start the flame. check it first to see if its still ok. be carefull in handling them, they are very fragile. check also for availability of gas. could have a closed valve.
Jan 30, 2008 | Kenmore 63942 Dryer
Dryer won't dry
  1. thermostate 2 the gas valve cylanoids the 2 black things on top gas valve can be bad will heat then stop heating 4 awhile thay drop out dont open valve watch your valve listen 4 it if comes on run heat goes off dont come back on 4 awhile 3 5 min bad valve cylonoids
Dec 29, 2007 | Kenmore 64952 Electric Dryer
Kenmore 73501 Model No. 11097350100
it could be your gas dryer ignitor, flame sensor or gas valve..do you smell gas? can you see the ignitor glow? if you can answer these questions I can help. Thanks
Sep 05, 2007 | Kenmore 73052 Gas Dryer
LG DLG6952 Gas Dryer Logo
89 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
