Question about Philips SA4010 MP3 Player
Mp3 player philips
My philips 1gb mp3 player keeps turning itself off,theres a little lock then bye !- does it need to be reset the manual is not very clear
  • coolf022 Dec 31, 2007
    I have the same problem: the MP3 player does not trun on after having it connected to my computer. Please provide me with a solution.
    Thanks,
    Francis.
  • Anonymous Jan 07, 2008
    When I want to select the Mode to play by Playlist, it just turns off!?
You have to unlock it i had the same prob : let th back of your mp3 face the floor andon the right you will see a button near the reset **** that button and turn it on
Posted on Sep 21, 2008
Once removed from the computer will not turn on/function. I have put a new battery in the device and the problem persists.
I can pull and transfer information, but once detached from the computer will not function.
Posted on Dec 12, 2007
SOURCE:
Have a phillips gogear 2gb that shuts off
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Feb 24, 2009 | Philips GoGear HDD6330 MP3 Player
My philips go gear mp3 wont turn on to charge
Take something really skinny like a saftey pin and press the little reset button thts next to the lock switch
Dec 17, 2008 | Philips GoGear HDD075/17 MP3 Player
Philips GoGear Model: SA 3025/37 Player will not turn off.
Hold in the left side of the inner middle button for 3-5 seconds. It should say "bye" on the screen. : )
Aug 27, 2008 | Audio Players & Recorders
Philips Go Gear 2GB
Look for the slide switch on the side of the player and turn it off.
Aug 14, 2008 | Philips GoGear SA178 MP3 Player
Craig mp3 1gb player cmp580d
this is a no brainer.....first thing I did was set up (formatted) the player with the disk drive utility supplied with mp3 player. Next you add in your MP3 songs. Turn on your player and with the mode button...go to MSC it will be highlighted black....then press in mode button to enter folder. Songs shouls be seen....and press power button to start.
May 15, 2008 | Audio Players & Recorders
Philips mp3 1GB SA3114/97 padlock symbol?
Slide the padlock lever on the left side from the up/on position to the down/off position
Mar 12, 2008 | Philips Audio Players & Recorders
Philips mp3 player
whenever i turn on my philips 1gb gogear it says player problem connect to pc.
Feb 01, 2008 | Philips GoGear HDD6330 MP3 Player
Philips GoGear 2GB MP3/Video Player LOCKED ?
you have to look at the side and shift the lock button
Nov 26, 2007 | Philips GoGear HDD075/17 MP3 Player
Philips SA4010 MP3 Player Logo
185 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
