Question about General Electric WDSR2120JWW 3.2 Cu. Ft. Top Load Washer - White
SOURCE: washer control knob just spins
The knob is prob stripped, very common for this washer.
Get it off and look at the teeth. To remove the knob you need a pair of surgical pliers. Reach behind the knob and yank the retaining clip out. If the teeth are smooth you need to replace the knob. Oil the timer so it will be easier to turn by the way. To put the new knob you simply slide it in place with the clip on it. So easy you won't believe it.
Posted on Feb 03, 2009
SOURCE: My GE washer #WDSR2080DEWW washer
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 13, 2011
SOURCE: GE washer model WWA8955 agitator
The agitator connects the part (transmission) that makes it agaitate by a piece in the bottom of the agitator and that connecting part has teeth on it that interlock on the transmisson shaft. That connecter is stripped so when trans. agiates that peice is slipping. That coupler needs to be replaced. This video here will show you how to replace that part. The part number for that peice is WH49X10042 it could be purchased at your local appliance parts store or online at,
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
assuredparts.com
I hope i have been able to help you fix your washer,GENE
Posted on Aug 15, 2011
SOURCE: GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
Posted on May 06, 2012
Mar 10, 2016 | GE Washing Machines
Jul 05, 2012 | General Electric WDSR2120JWW 3.2 Cu. Ft....
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Jan 15, 2018 | Whirlpool Washing Machines
Sep 15, 2011 | GE Washing Machines
Aug 13, 2011 | GE WDSR2080D Top Load Washer
Jul 24, 2011 | GE Washing Machines
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Jul 20, 2009 | GE WPGT9360EPL Top Load Washer
Feb 03, 2009 | GE WBSR3140DW Top Load Washer
42 people viewed this question
