Question about GE Profile Harmony DPGT750EC Electric Dryer
Blower motor not always coming on
Already replaced blower motor and inlet thermistor and still having issues. I have to cancel settings and restart several times before blower motor finally revs up to speed then dries great until it gets to cool down mode then starts to make very loud groaning noise. I have thoughly disassembled and cleaned out machine and have also diconnected vent hose. What can I test next?
    Sergeant:
  • 479 Answers
The blower wheel is attached to the dryer motor if the motor is running the blower is moving unless the shaft end is worn out the blower threads onto the motor shaft
Posted on Nov 23, 2013
Master_Tech
  • 770 Answers
SOURCE: GE Profile Harmony DPGT750EC Blower/Temperature... Problem
please post your email i will send you the service manual
Posted on Jan 25, 2008
SOURCE: GE Profile Electric Dryer, Blower nt getting up to speed
On all the ones I've seen with this problem, they've needed a new blower motor. Don't take that as the golden answer because even G.E. tech support doesn't know. It could be the control board, but I haven't seen that yet. G.E. always recommends replacing the inlet thermister, which is accessed through a little cover on the back. Good luck & welcome to the wonderful world of complex electronic appliances.
Posted on Jan 28, 2008
  • 54 Answers
You need to replace the blower motor. It says you are having temp problems because the blower is quitting and the heater is overheating.
Posted on Jul 04, 2008
  • 45 Answers
SOURCE: GE Harmony Dryer dries fine one time won't quit sensing the next
The thermostatic fuse is getting hot during the run cycle and then staying open until the dryer cools down completely.
You may fix just by cleaning out the entire dryer. Remove the top cover and vacuum out thoroughly. Replace a torn lint screen and make sure your exhaust conduit is not leaking lint everywhere.
If you can't fix by cleaning, you will have to replace the thermostat which is a $5 part byt a $100 repair.
Posted on Jun 28, 2009
SOURCE: GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Posted on Mar 23, 2010
How to replace heat blower
NOTE: The blower motor is located on the passenger side of the vehicle under the instrument panel. The blower motor can be removed from the vehicle without having to remove the HVAC housing.
  1. Disconnect and isolate the negative battery cable.
  2. Remove the passenger side cowl trim panel. See: Body and Frame\Interior Moulding / Trim\Trim Panel\Service and Repair\Cowl Trim
  3. Pull back the carpet to access the front upper screw that secures the air inlet housing.
  4. Remove the recirculation door actuator.
  5. Remove the recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside.
  6. Disconnect the blower motor wire lead connector from the blower motor resistor or power module, depending on application.
118348823 Lower Air Inlet Housing
  1. Remove the one screw (from the top) that secures the lower air inlet housing to the upper air inlet housing.
  2. Remove the four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing.
118348824 Blower Motor Wire Lead Grommet
  1. Push the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  2. Feed the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  3. Position the recirculation-air door as necessary to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  4. Gently flex the recirculation air door far down enough to remove the blower motor and wheel from the HVAC housing.
118348825 Blower Motor Mounting Tabs
  1. Remove the blower motor and wheel from the HVAC housing. Note the position of the blower motor mounting tabs.
INSTALLATION
Nov 28, 2011 | Chrysler Sebring Cars & Trucks
My a/c blower intermittently stops working in all settings. It has a new blower which was installed one month ago. Vent, recirculate and a/c lights will come on when pushed and the compressor will run but...
The blower might be at fault,bump the blower motor,sometimes they will start working if the blower motor is bad,but not always,make sure it is getting voltage to the blower motor,if it is,replace the blower motor.If this was at all helpful,please rate,thank you.
Aug 20, 2010 | Chevrolet Impala Cars & Trucks
Where is the blower motor... i know that is the problem, but where and how do I change it. i already have the part
Blower Motor Removal & Installation Front To Remove:
NOTE: The blower motor is positioned on the passenger side of the vehicle beneath the instrument panel, and can be removed from the vehicle without removing the HVAC housing.
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Passenger side cowl trim panel
    • Carpet to access the front upper screw that secures the air inlet housing
    • Recirculation door actuator
    • Recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside
    • Blower motor wire lead connector from the blower motor resistor or power module, depending on application. Lower Air Inlet Housing chr_pacific_lwr_inlt_hsng.gif
    • One screw (from the top) that secures the lower air inlet housing to the upper air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing Blower Motor Wire Lead Grommet chr_pacific_blwr_wrg_grmmt.gif
  3. Feed the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  4. Push the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  5. Place the recirculation-air door as needed to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  6. Lightly bend the recirculation air door far enough down to remove the blower motor and wheel from the HVAC housing. Blower Motor Mounting Tabs blwr_mnting_tabs.gif
  7. Remove the blower motor and wheel from the HVAC housing. Make a note of the location of the blower motor mounting tabs.
To Install:
  1. Install or connect the following:
    • Blower motor and wheel to the lower half of the HVAC housing and line up the blower motor mounting tabs to the correct location on the HVAC housing
    • Blower motor and wheel into the HVAC housing by lightly bending the recirculation-air door far enough down
    • Three screws that secure the blower motor to the HVAC housing by positioning the recirculation-air door as needed
      1. Torque to: 17 inch lbs. (2 Nm)
    • Blower motor wire lead through the opening in the lower air inlet housing and seat the rubber grommet into the lower air inlet housing
    • Recirculation-air door pivot into the lower air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and the lower HVAC housing
    • Blower motor wire lead connector to the blower motor resistor or power module, depending on application
    • Recirculation door actuator wire lead into the routing clip located on the lower air inlet housing
    • Carpet
  2. Perform the heater-A/C control calibration procedure.
Rear To Remove:
NOTE: The rear blower motor and blower wheels are repaired only as a balanced unit. The entire blower motor and wheel assembly must be replaced if either component is fault or damaged.
    • Front center floor console cover
    • Negative battery cable Rear Blower Motor Housing chr_pacific_rear_blwr_hsng.gif
    • Body wire harness connectors from the rear blower motor power module and the rear mode door actuator
    • Body wire harness bracket from the console support bracket
    • Eight screws and the two console support brackets from the floor console base and duct assembly
    • Four screws that secure the rear blower motor housing to the floor console base and duct assembly
    • Rear blower motor housing and place it on a bench
    • Rear blower motor wire harness connector from the power module
    • Eleven retaining clips and three screws that secure the housing together
    • Two halves of the housing
    • Blower motor wire harness and grommet from the housing and remove the blower motor
To Install:
    • Rear blower motor into the housing and install the blower motor wire harness and grommet
    • Two halves of the rear blower motor housing and install the eleven retaining clips and three screws
    • Rear blower motor wire harness connector to the rear blower motor power module
    • Rear blower motor housing into the floor console
      2. Two console support brackets onto the floor console base
      3. Eight screws that secure the support brackets to the floor console base
      4. Body wire harness bracket onto the console rear support bracket
      5. Body wire harness connectors to the rear blower motor power module and the rear mode door actuator
      6. Negative battery cable
      7. Front center floor console
  2. Calibrate the A/C-heater control.
Aug 13, 2010 | 2004 Chrysler Pacifica
Dec 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Blower motor wont come on
Replace the blower resistor. The control head provides a ground circuit through the resistor block which reduces current flow to the blower motor which in turn gives you the different blower speeds.
Aug 29, 2009 | 2001 Dodge Durango
98 gmc pu blower doesnt always work.
Ive ran across this many times its usually the blower motor but I found that if I replace the blower and the replacement plug(thru GM)that the vehicles never had a blower issue again,so order up a motor and plug and be sure to solder the new plug dont use crimp fittings.have a good day DB
Feb 04, 2009 | 1998 GMC Sierra
Blower for heater stopped
Remove the hush panel under the dash and unplug your blower motor turn the knob and see if its getting power. If it is replace the blower motor. If your heater seems to work on high but not the other 4 settings. replace the blower motor resistor and pigtail (same general location as blower motor)
Jan 31, 2009 | 2004 Chevrolet Silverado 2500HD
Follow up question for 2000 Saturn Blower Motor Issue
The thermistor is in the winding of the blower motor. Letting it cool down will let it run, but probably not long. the thermistor is not replaceable, replace blower motor
Feb 27, 2017 | 2000 Saturn SL
Blower motor
Hill, which blower motor? The exhaust inducer or the room air blower? If you are referring to the exhaust blower, check for a restriction in either the fresh air inlet, exhaust pipe or condensate line. If you are referring to the room air blower and you already replaced the motor, it is most likely a relay on the control board. You will need to replace the whole board. More info is always better!
Apr 11, 2008 | Ruud UBHC Air Conditioner
Jan 27, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
57 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
