Question about Juki TL-98QE Mechanical Sewing Machine
Reverse lever stuck down.
Reverse lever won't come up
Singer simple sewing machine will not move forward, but will sew reverse with holding the reverse lever down like it is supposed to do. I have been sewing for 50+ years. No simple answers please
Sorry--the only thing I can find is that possibly the auto reverse is turned on. Other than that, perhaps contact Singer directly or take it for service.
3221 SIMPLE Singer Sewing
Jul 08, 2016 | Singer Sewing Machines
Bernina Bernett 55 is stuck in reverse
make sure it's not in the buttonhole setting, and if the machine
isn't in the buttonhole setting and the buttonhole lever isn't down
then it would be a good idea to have the machine checked to see
why the machine ins stuck in reverse.
Dec 13, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
Europro model 6131 is stuck in reverse
I have never found any online instruction manuals and repair manuals are just as non-existent.
You can try jiggling the reverse lever while turning the hand wheel. Other than that the only suggestion I have is to use the machine for target practice.
Oct 02, 2012 | Euro-Pro 6131 Mechanical Sewing Machine
Reverse lever won't work
take off the top again and take a good look while pushing the reverse lever. See if you can see what the problem is.
Aug 22, 2012 | Toyota Sewing Machines
The take up lever on my morse 400 super dial sewing machine does not move up and down, It is stuck. What can I do to fix this problem?
it won't be the take up lever it is a false impression, take the bobbion case and raceway out and you will probably find thread stuck
Aug 15, 2011 | Sewing Machines
1) The lever at the back that keeps the foot up when threading etc will not stay up on it's own. When you put it up, it just falls bak down a second later. 2) The needle won't go up and down,...
it sounds like the take up lever has either come loose or is broken, & since the needle won't go up & down it needs to be checked
Aug 02, 2011 | Singer 1507
Machine sewing backwards
the reverse lever may be stuck. this is usually located on the right hand side of the machine, and is a lever that you can push down. sometimes it's a switch.
May 28, 2010 | Singer 5050 Mechanical Sewing Machine
Lever is stuck in reverse
If the stitch length bar, which is located on the right side of the machine, is in the up position move it down to where the numbers are. Those numbers are referring to how many stitches the machine will sew in an inch. Therefore, if you put it on 10, your machine will sew 10 stitches per inch. It being up will cause your machine to go in reverse.
Jul 26, 2009 | Brother LS-1217 Mechanical Sewing Machine
Husqvarna Viking Sweden Model 6030
On all sewing machines there is a button or lever which makes the machine go backward. The button could be stuck, if so put a drop of oil on it and try to release it. If there is a lever that has been raised which puts the machine in reverse, simply lower it to the lowest position. This should solve the problem.
Zelma
Nov 29, 2007 | Husqvarna Viking 1
Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Oct 26, 2007 | Kenmore 15208 Mechanical Sewing Machine
Juki TL-98QE Mechanical Sewing Machine Logo
29 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
