Question about Quartet gbc Gbc Velobind System 3 Pro 90 Day Warranty
Gbc velobind system 3 pro troubleshoot - Quartet gbc Gbc Velobind System 3 Pro 90 Day Warranty
Top roller of GBC ultima 65 not heating
either the top heater tube, (inside the orange/red roller) is burned out (Open) or the wire on either side of the heater tube is burned or broken in half. It\'s not as bad as you might think.
westco laminating services....405-324-6092
Oct 23, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Gbc ultima 65 won't heat up.
Could have a bad heat lamp, do your adhesive feel tacky on any of the rollers? Are you may have a bad triac
Oct 02, 2013 | Gbc HeatSeal Ultima 65 Laminating System
My gbc heatseal h300 wont feed paper.
I have the same machine, GBC H-300. I have it apart right now, and found the feed motor gear in pieces.
Motor Gear 18T 120v part #26700056
Mike Dettling
May 26, 2011 | Grilling
I need a user manual for Velobind System 1
I Will advice you check manualsonline.com to search for it.
Apr 27, 2011 | Office Equipment & Supplies
DISCONNECTED WIRE
I clipped all the zip ties to free up the harness and physically inspected every connector till I found a connector that seemed rather loose and came off with minimal force. I then gathered the 3 wires and install a #18 wiring nut. the shredder is fully functional again.
Jun 03, 2009 | Quartet gbc GBC 10-Sheet Cross-Cut...
Quartet gbc Gbc Velobind System 3 Pro 90 Day Warranty Logo
136 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
graybeard32301
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
