Question about Bell & Howell DNV16HDZ Full HD Rogue Night Vision Camcorder, 16MP, 3" LCD Monitor, 10x Optical Zoom & 100x Digital Zoom, 1920 x 1080p Resolution, Blue
After recording I hear sound via my camera of the recorded program but when I take the SD card containing the video footage and play it thru my computer I see a picture with no sound.
My DCR-SR33 has no USB port?
See page 35 of your manual. This camcorder can play recorded images and video footage to a TV using the supplied cables. The same cable can plug into an AV/USB convertor enabling the digital recording of what you have recorded to your computer.
Jul 14, 2017 | Sony DCR-SR32 DCR-SR30 DCR-SR33
I recorded a video on my samsung sc-dc 164 camcorder and i used my SD memory card instead of the disc. when i try to play my video from the SD card recording it won't play but can only hear audio from my...
how did you transfer the video from the card to your PC?
did you connect the camcorder to your PC or did you use a memory card reader?
if you can play the audio then what you need is the right video codec for the unit
try searching for video codecs through search engines
make sure that the software that you are using to play the video plays the file format of your video,
try using roxio, then connect the camcorder to your computer via USB, make sure that the drivers are installed, play the video through your camcorder then use roxio to capture it real time instead of the usual "copy-paste"
Jun 28, 2009 | Samsung SC-DC164 DVD Camcorder
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
Jan 01, 2009 | Canon XH A1 Mini DV Digital Camcorder
I want to copy video footage from the tape to the sd card.
Hi!
You cannot transfer the video from Mini-DV to SD card within your camera as your camcorder does not have this feature. If your purpose for finding this function is to transfer your footage to your computer, you may try using the firewire port in your camera to connect it to your pc.
If you need help with the firewire connection, feel free to post a follow up.
Hope this helps!
Nov 11, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
No sound when playing back video footage
If there is an external microphone jack on the camera, it would help if you tried recording with an external microphone. Also, the mini DV's will mute the sound if the tape guides are slightly out of adjustment. You can tell if they have moved by trying a known good sound tape in the machine. If that plays with no sound also, the tape guides have moved out of alignment.
Sep 16, 2008 | JVC GR-DX97 Mini DV Digital Camcorder
Cant play back recorded footage
you have to flick the switch on the side from camera to play
Jun 29, 2008 | Canon MV650i Mini DV Digital Camcorder
Trying to play off-camera stored video, when replaced onto SD card in camera
Did you change the file name on the original video? Are you able to put the video back onto the camera? If you changed the file name, you can't put it back onto the camera. It also needs to be in AVI format which is the video format that the camera records in.
Hope this helps!
May 28, 2008 | Canon PowerShot S5 IS Digital Camera
Playing back footage on pc
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Feb 17, 2008 | Video Cameras
Importing video from memory card
it;s a codec problem (audio and video ). Find out with what method and codec the camcorder works...
U can also try more video players until it works (if u dont know what codec u need )....
(u should install the drivers for the cam on the computer , it should contain the needed decoder .... )
Jan 21, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Canon SD 700 IS Movie Sound Issue
This is because of low light and low frame rates in the camera. It records the sound on time but the picture delays. In the camera's video menu, choose a higher frame rate to help this a little. Honestly though, If you want to shoot better video get a video camera.
Sep 14, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Bell & Howell DNV16HDZ Full HD Rogue Night Vision Camcorder, 16MP, 3" LCD Monitor, 10x Optical Zoom & 100x Digital Zoom, 1920 x 1080p Resolution, Blue Logo
37 people viewed this question
Top Bell & Howell Video Cameras Experts
abdul rauf
abdul rauf
Richard Lane
Steve
Are you a Bell & Howell Video Camera Expert? Answer questions, earn points and help others
