Question about Saeco Vienna Espresso Machine
Steamer still works but milk foam is flat. - Saeco Vienna Espresso Machine
    Habit-Forming:
  • Saeco Expert
  • 130 Answers
Probably you have to decalcify the machine
Posted on Dec 30, 2013
2 Suggested Answers
Clog2020
  • 81 Answers
SOURCE: the automatic foam dispenser is
Try here:
http://www.wholelattelove.com/tips.cfm?itemID=11
Has a lot of useful information that should fix your problem.
Posted on Apr 20, 2008
My steamer is not working properly
Take the nozzle off and wash well also there is a small hole pin size at the top clean out with a pin and push the black inside piece inside nozzle out 2/3 MM out it must pop out I use a chop stick it's perfect. I had the same problem perfect now
Nov 07, 2015 | Gaggia Titanium Espresso Machine
Steamer Button doesn't work
hi ROC,
the steamer works? can you do foam with milk?
perhaps its the thermostat to regule the heat.
sorry, my english level is low, im french.
Apr 15, 2014 | Gaggia GRAN Espresso Machine Cappuccino...
How do i use the foam setting?
It depends on what type of espresso maker you have. Some have two boilers, many only have one. For the ones with a single boiler, there will be a dial or button to raise the temperature of the boiler enough to steam the milk into foam. Just be sure to drain the line of any excess water first. Once the water stops and steam starts coming out, then you can use the steamer to create foamy milk.
Jun 16, 2011 | Coffee Makers & Espresso Machines
Hi, I bought my kitchenaid artisan coffee machine on ebay. I can't get the steaming of the milk right. It froths too much so can't make just a latte or flat white. It looks to me that the nozzle...
there is an art to working a foamer ... hence the "artisan" in the coffee-maker's name. There are several aspects to a good foam:
1. If you have been using regular milk to make your foam, try half-and-half ... the thicker consistency will give you a different result.
2. If you have been jamming the foamer head all the way to the bottom of the milk while you are foaming it, try submerging less of the foamer ... this will cause the steam to have a slightly different effect on the milk. If you have been submerging it only about half way (or not at all) try different depths. If one consistent depth is not right, try swirling it around while you foam the milk.
3. Try a different amount of steam (if your steam release valve is adjustable). Pushing a lot of pressure into the milk will give you a different result than barely turning it on.
4. Are you using a cold container or a warm one to hold the milk you are steaming? If you are still not getting the results you are looking for by playing with the other aspects of your foaming process ... try a different container (it sounds silly, but it can really help).
Before you go out and spend a bunch of money on different replacement parts for your machine, spend a while playing with these aspects of your foaming process. If none of these ideas help, then you should consider replacing pieces. Foaming milk is not as easy as it sounds ... it took me a few months of (once daily) use to really get my technique down so I could make a reliably decent foam. Don't give up! and good luck!
Jun 01, 2011 | KitchenAid Artisan
I have a Gaggia "Coffee"
First thing I would check is the end of the steam wand to make sure it is not blocked. Then if you are getting hot water for making espresso, I would remove the top cover and check the topmost thermostat.
Apr 22, 2011 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
The milk is not getting foamy. Steam comes out the pipe and heats the milk, but, no foam.
My only non professional suggestion is to take off the rubber cover on the steamer and make sure that and the metal steamer itself is clean.
Aug 08, 2010 | Kalorik Aqua Espresso Maker
Capipuccino automatic steamer is running for two seconds. This is not enough because it does not foam the milk. How do i fix it to make it steam longer
Go to the Menu screen and scroll down or up till you see the Cappuccino Sec....enter and select ON/ or OFF. Make it OFF for manual timing.
May 20, 2010 | Saeco Royal Exclusive 30153 Espresso...
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Hi, we have a Krups espresso machine, model fnd1. We can't seem to make the milk steamer work, it will make the milk REALLY hot, but not foamy. Do you replenish the steam supply somewhere? Is there a...
suggestions include very cold milk.  having the nozzle just barely in for frothing.
On my model there's an air passage in the nozzle that foams quite nicely.  If you have that too, it might be clogged with milk.  You have to keep these clean with every use.
Jul 11, 2008 | Krups XP4030 Espresso Machine
Frothe the milk?
he trick to this is making sure you have steam comming out of the wand and not water. To do this, make sure you get the steam started before you begin. To get a light foam that will not deflate, hold the wand just under the surface of the milk. You should hear a steady, high pitched noise and you should not hear the splatter of bubbles popping on the surface. Popping noises mean that the wand is too high in the milk and your froth will not hold up. A low pitched noise from the cup means that the wand is too far down in the milk. This will heat your milk (for hot chocolate), but will not give you a good foam. Good luck!
Dec 27, 2007 | Jura Capresso CapressoBAR 351 Coffee...
Saeco Vienna Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
