Question about Whirlpool Dryers
Need to replace my dryer timer M460-G
The new timer does not look quite like the old one.
    Problem Solver:
  • 9 Answers
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
C / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)need to replace my dryer timer M460-G - 6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
Posted on Oct 06, 2017
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Look at the numbers and letters on the old timer and match the wire to the same numbers or letters on the new "R to R , TM to TM, N to N and so on also you might have a wrong part
Posted on Nov 22, 2013
ned_san_jose
  • 234 Answers
SOURCE: i need a timer for the M460/g kenmore elete dryer
repairclinic.com has the best selection of timers. imo
Posted on Sep 18, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Hello, My GE Dryer, Model M460-G timer won't shut off
Sounds like you have a faulty timer switch, check with your local supply house and get the same type of switch.
When you go to replace the timer switch, unplug the dryer, then remove one wire at a time. This will prevent wiring mix-ups.
Good luck,
I hope this helps
Posted on Oct 11, 2009
Testimonial: "Thanks for your help, I greatly appreciate it.We live in the middle of no where so I will have to order it online once I figure out the correct part #"
SOURCE: I have a 70 series Kenmore dryer. The timer quit
Hallo, if your new timer is not equal to the old one. It is the problem. need change timer.
Posted on Jan 30, 2010
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
Fix-Fox
  • 7 Answers
Here you go again :-)
Bought a new dryer timer. The recommended part for Kenmore dryer model 110.97281100 is WP3398190. The old timer model is M460-G and 3391658. Things do not line up exactly.
From your description, it seems you do not have an exact replacement. See what www.searspartsdirect.com has to say. Don't be surprised if you get several different answers.
Nov 07, 2016 | Kenmore Dryers
Old whirlpool thin/twin Dryer timer old timer M404-G New timer M460-G how to hook up
The problem as stated is that the new M460-G timer does not have the same pins as the old one (because there seem to be a variety of sub-models under the M460-G name). However, I have successfully (at least to provide the timed heat function) used a different M460-G on my Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, I had to figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also by inspection of a wiring diagram at appliance pros dot com
A / Gas / Org
c / Motor / Wh
BK / Motor / Wh
R / Gas / Org
OR / ? / Pink (figured it was safe)48146720-bbc3-47da-833c-6d50a0cf5df0.jpg
Sep 06, 2015 | Whirlpool Dryers
How do I fix a Kenmore dryer with model # M460-G that does not have any heat
M460 means nothing as far as failures, it is a designation of a style of timer from Midwest timers. If you had no heat it could be the heating element, a safety limit, a control problem like a burnt timer contact, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Feb 05, 2010 | Dryers
Good luck,
I hope this helps
Oct 11, 2009 | GE Dryers
I need a timer for the M460/g kenmore elete dryer the number on timer is o14-96648
Sep 17, 2009 | Kenmore Dryers
Dryers Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
