Wear would you find it
SOURCE: craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
SOURCE: I received an answer for a 25cc gas trimmer,
The routing of the fuel lines is the same. If you have 3 lines, that means the primer bulb is not directly mounted to the carb, rather it is connected to the carb with hoses.
Line 1. Comes from the fuel filter in the tank (smaller diameter hose) directly to the inlet port on the carb. This is the port that is opposite the diaphragm on the carb. Diaphragm is held on with 2 or 4 screws through a chrome plate. Make sure to leave enough hose so the fuel filter will fall to the lowest point of the tank when it is being used.
Line 2. Goes from the other port on the carb to the short side of the primer assembly.
Line 3. Goes from the longer port of the primer assembly and returns to the tank. Sometimes this line will have a simple coupler on the inside of the tank, but it is optional and its only function is to keep the line from slipping out. If yours does not have this coupler, just leave an inch or two of line in the tank.
*If both ports on the primer are the same length, you can test to see which is pushing air out...that's where line 3 goes.
SOURCE: Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
